On Thu, Dec 15, 2005 at 09:08:19AM -0600, Chithra Karunakaran wrote:
> Hi:
> Has anyone worked with Oxford Danfysik Beam Position monitoring system
> (4 channel IC plus Electronics Unit, YMCS0012). The device does not
> respond to any of the commands send through the serial port.
> Thanks,
> Chithra.
Hi. I have.
I am able to communicate with it with the following RS-232 settings:
Baud rate: 19200
Data format: 8 bits
Stop bits: 1
Parity: none
Flow control: none
Also, if you have only one device (i.e. you are not chaining the
devices), your RS-232 cable must be wired correctly. The wiring should
be as follows:
VME <-> QBPM
2 3
3 2
5 5
4-6-8
On the end that connects to the VME IOC, pins 4, 6, and 8 should be tied
together.
If you have more than one device, the wiring needs to be different (see
section 6.6 on page 13 of the manual).
A command you can send is ":READ1:CURRALL?" terminated with "\n" (ASCII
10 / linefeed) to read all four current channels at once. Replace the 1
after "READ" with the unit address assigned to your device. Or if you
don't know it, try 0-15 if 1 doesn't work.
Hope this helps.
-lewis
J. Lewis Muir
Software Engineer
CARS/IMCA-CAT
- Oxford Danfysik-YMCS0012 Chithra Karunakaran
RE: about CA monitor Jeff Hill
<2005>
2025
2026
RE: Oxford Danfysik-YMCS0012 Walters, M (Malcolm)
<2005>
2025
2026
