1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: about CA monitor
To: "'huangsong'" <[email protected]>
Cc: <[email protected]>
Date: Thu, 15 Dec 2005 09:18:01 -0700
> But can I get the value of VAL field when camonitor RVAL field?
> I want to get the value of VAL & RVAL field when camonitor one field.
> DBR_TIME_XXXX just return the value of specified field.
As Andrei has mentioned it is of course possible to set up two subscriptions
(one for VAL and one for RVAL), but that appears to not be what you are
after.
It isn’t easy to receive both VAL and RVAL as an atomically packaged
subscription update with the current versions of EPICS. One possibility
would be to create a waveform record with two elements. You might arrange to
atomically copy the ai's VAL and RVAL fields into the waveform record's two
elements. You might then monitor the waveform record, and receive the two
elements atomically with each subscription update. Admittedly, that is a
somewhat contrived solution.
The Data Access library that Ralph Lange and I have been working on
facilitates flexible packaging Channel Access data. It is designed to
seamlessly eliminate limitations of this type.
Jeff
> -----Original Message-----
> From: huangsong [mailto:[email protected]]
> Sent: Wednesday, December 14, 2005 6:10 PM
> To: Jeff Hill
> Cc: [email protected]
> Subject: Re: about CA monitor
> Hello, Jeff Hill
> On Wed, 14 Dec 2005 10:52:13 -0700
> "Jeff Hill" <[email protected]> wrote:
> > Hello Huang, Song;
> > > I use Channel Access Monitor function to monitor a PV (VAL field).
> > > When event triggered, it returns the value of VAL field, timestamp,
> alarm
> > > status and other things.
> > > But I also want to get the value of other fields (e.g. RVAL) when
> event
> > > triggered.
> > > In db_Access.h, it seems all types can't do this.
> > > Do I have to get the value of other fields in Event Handler?
> > One possibility would be to set up a subscription using type
> DBR_TIME_XXXX
> > on channel "<record name>.<field>" expecting to receive the value of the
> > specified field along with the time stamp and the alarm status of the
> record
> > For example we can test this as follows:
> > > camonitor aiExample.RVAL
> > aiExample.RVAL        2005-12-14 10:42:25.992078 0 LOLO MAJOR
> > aiExample.RVAL        2005-12-14 10:43:23.994643 3 LOW MINOR
> > aiExample.RVAL        2005-12-14 10:43:24.994700 3
> > aiExample.RVAL        2005-12-14 10:44:04.996487 4
> > aiExample.RVAL        2005-12-14 10:44:05.996576 4 HIGH MINOR
> > All the best,
> > Jeff
> > > Sent: Wednesday, December 14, 2005 1:46 AM
> > > To: [email protected]
> > > Subject: about CA monitor
> > > Hello,
> alarm
> event
> > > triggered.
> > > Best wishes and regards.
> > > Huang,song
> > > [email protected]
> Huang,song 黄松
> [email protected]
Re: about CA monitor huangsong
Prev: Re: Oxford Danfysik-YMCS0012 J. Lewis Muir
Next: RE: Oxford Danfysik-YMCS0012 Walters, M (Malcolm)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: about CA monitor huangsong
Next: RE: about CA monitor Liyu, Andrei
