1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: epics extension
To: Ralph Lange <[email protected]>
Cc: Christophe Moins <[email protected]>, EPICS Tech Talk <[email protected]>
Date: Wed, 21 Dec 2005 09:15:01 -0600
Ralph Lange wrote:
As long as you have both styles of applications in your extensions tree, you will have to have both configuration directories: .../config for your 3.13 style apps and .../configure for your 3.14 style apps. Note that all applications will be compiled against 3.14 - you don't have to install a 3.13 base! - but in the extensions tree both configuration directories have to be present to use the compatibility mode. Install both tars (extensionsConfig_20040406.tar.gz and extensionsConfigure_20040406.tar.gz) into your extension tree to make it work for both 3.13 and 3.14 style applications.
As an additional note bear in mind that to use the compatibility stuff with a 3.14.x version of base you have to configure the base/config directory (CONFIG_SITE, RELEASE, possibly some other files) in the same way that the base/configure directory is set up - you won't have had to do that before now, so you probably haven't done it yet.
- Andrew
PS: If you do decide you want to try converting an application to the 3.14 build system, it's a good idea to mail the maintainer or tech-talk first, they may have already done most of the work but not published it yet. You can also check the CVS repository browser or the nightly snapshot to see if anything has been done towards the conversion, if the extension is one that is kept in our repository.
* * Matt Santos / / For a Brighter America * *
Re: epics extension Emmanuel Mayssat
epics extension Christophe Moins
Re: epics extension Ralph Lange
Prev: Re: epics extension Ralph Lange
Next: Re: epics extension Emmanuel Mayssat
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
