1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: about using NI-1014 with VME/Linux
To: Jun-ichi Odagiri <[email protected]>
Cc: [email protected]
Date: Sun, 25 Dec 2005 13:03:16 -0600
On Dec 22, 2005, at 7:39 PM, Jun-ichi Odagiri wrote:
Dear Eric;
I'd like to thank you for your reply.
I think I should have explained why I'm trying to do the work.
Using NI-1014 in itself is not the purpose of the work.
What I'd like to do is to confirm that a library developed by Dr. Kim Kukhee
to support VME-bus access works well for J-PARC control.
The reason I chose NI-1014 is, as far as I know, its driver is the most
complicated one, since the board uses interrupts and DMA.
If I can make it work with the library, I thought I could say,
"OK, I may be able to support any kind of boards with the library."
That's the goal of the work.
Yes, that would be a good learning experience, but I should mention that the NI-1014 driver distributed with the ASYN package does not use DMA.  Marty and I had a long look at the hardware description and found so many race conditions that we felt it better to use interrupt-driven I/O.    In fact we've just been informed that we may need to add some more busy-loops to get the hardware to work with fast PowerPC VME processor cards.
The library works on top of a kernel level driver supplied by the
manufacture of the VMIVME-series CPU, and maps the VME address space into
the address space of a user process.
The library offers functions something like "sysBusToLocalAddr",
"intConnect", ... to be called by normal user process.
I'm thinking of running the NI1014 driver in user space by using the
library.
(I never want to work in the Linux kernel space. I know how hard it is.)
Having told you the background, I'd like to ask you the following questions
again.
How is the driver of NI1014 supposed to be used in user mode on Linux?
Is it supposed to work with some specific library in EPICS Base?
How the driver was tested when it was developed?
What was the platform for the development?
The NI-1014 driver was not written with Linux in mind and certainly not Linux in user-mode.  Marty Kraimer and Ron Sluiter have done extensive tests of the driver on vxWorks and I have some some very quick tests on RTEMS.  It was Ron's testing that recently revealed the problems with fast processors.
I thank you a lot for this support.
We are using this support for several different applications here at KEK.
It's working just fine for us.
My colleague and I recently found that if the firewall was enabled on Linux
(Scientific Linux), invocation to the Linux RPC-library (clnt_call) gets the
IOC process a core dump, for that matter.
Do you have a stack trace you can send to show where the problem is occurring?
Eric Norum <[email protected]>
Advanced Photon Source
Argonne National Laboratory
(630) 252-4793
RE: about using NI-1014 with VME/Linux Jun-ichi Odagiri
Prev: RE: Problem with XML RPC Waggoner, Bill
Next: building EPICSR3.14.8.1 on MacOSX 10.3/10.4 Noboru Yamamoto
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: about using NI-1014 with VME/Linux Jun-ichi Odagiri
Next: Job Opening at PPPL Paul Sichta
