1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: about using NI-1014 with VME/Linux
To: "'Eric Norum'" <[email protected]>
Cc: <[email protected]>
Date: Fri, 23 Dec 2005 10:39:05 +0900
Dear Eric;
I'd like to thank you for your reply.
I think I should have explained why I'm trying to do the work.
Using NI-1014 in itself is not the purpose of the work.
What I'd like to do is to confirm that a library developed by Dr. Kim Kukhee
to support VME-bus access works well for J-PARC control.
The reason I chose NI-1014 is, as far as I know, its driver is the most
complicated one, since the board uses interrupts and DMA.
If I can make it work with the library, I thought I could say,
"OK, I may be able to support any kind of boards with the library."
That's the goal of the work.
>I expect that this will be quite a bit of work. The EPICS Linux support
>runs only in user mode but the NI1014 driver would have to run in the
>kernel.
The library works on top of a kernel level driver supplied by the
manufacture of the VMIVME-series CPU, and maps the VME address space into
the address space of a user process.
The library offers functions something like "sysBusToLocalAddr",
"intConnect", ... to be called by normal user process.
I'm thinking of running the NI1014 driver in user space by using the
library.
(I never want to work in the Linux kernel space. I know how hard it is.)
Having told you the background, I'd like to ask you the following questions
again.
How is the driver of NI1014 supposed to be used in user mode on Linux?
Is it supposed to work with some specific library in EPICS Base?
How the driver was tested when it was developed?
What was the platform for the development?
>The ASYN VXI11 driver does run on Linux.
I thank you a lot for this support.
We are using this support for several different applications here at KEK.
It's working just fine for us.
My colleague and I recently found that if the firewall was enabled on Linux
(Scientific Linux), invocation to the Linux RPC-library (clnt_call) gets the
IOC process a core dump, for that matter.
Thanks a lot in advance.
J. Odagiri
Re: about using NI-1014 with VME/Linux Eric Norum
Prev: Re: about using NI-1014 with VME/Linux Eric Norum
Next: RE: Problem with XML RPC Waggoner, Bill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  <20052006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: about using NI-1014 with VME/Linux Eric Norum
