1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Variable scan rate
To: Emmanuel Mayssat <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Thu, 5 Jan 2006 12:37:49 -0500 (EST)
On Thu, 5 Jan 2006, Emmanuel Mayssat wrote:
> The record starts in passive mode When I change the temperature
> settings, the record should have a high scan rate. When the readback
> stabilizes, the scan rate should decrease and after some amout of time
> go back to passive.
The SCAN field can be modified at runtime. You can have some routine do a
put into this field, or perhaps do it within the database using a calc and
an mbbo or a calcout. I have a couple of records where the SCAN rate can
be set by the operator using an MEDM "menu" button. But for something like
the temperature readback, I would just leave it at the fast rate all of
the time.
Steve Hartman
[email protected] || 919-660-2650
Duke Free Electron Laser Laboratory
Re: Variable scan rate Maren Purves
Re: Variable scan rate Emmanuel Mayssat
Building JCA1 John Faucett
Prev: RE: Variable scan rate Dalesio, Leo `Bob`
Next: Re: Variable scan rate Maren Purves
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Variable scan rate Emmanuel Mayssat
