1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: pv connect/disconnect callbacks
To: EPICS tech-talk <[email protected]>
Date: Wed, 11 Jan 2006 17:59:33 -0500
Are channel callbacks delivered in the context of a different thread from that
of main in a single-threaded application?
A disconnect callback backtrace looks like this:
#1  0x08129b96 in EPICS_ProcessVariable::ca_connect_callback (arg=
      {chid = 0x982e390, op = 7}) at epics_pv_factory.cc:226
#2  0x00fbf6ea in oldChannelNotify::disconnectNotify ()
   from /epics/supTop/R3.14.5/base-3.14.5/lib/linux-x86/libca.so
#3  0x00faeda8 in nciu::unresponsiveCircuitNotify ()
#4  0x00fb86a3 in tcpiiu::removeAllChannels ()
#5  0x00fa290d in cac::destroyIIU ()
#6  0x00fb3680 in tcpSendThread::run ()
#7  0x0015e55b in epicsThreadCallEntryPoint ()
   from /epics/supTop/R3.14.5/base-3.14.5/lib/linux-x86/libCom.so
#8  0x001640e9 in start_routine ()
#9  0x00bae98c in start_thread () from /lib/tls/libpthread.so.0
#10 0x00a2f7da in clone () from /lib/tls/libc.so.6
A value change callback backtrace looks like this:
#0  XtextDspUpdate (pv=0x8cca3a8, userarg=0x8cc7da0) at x_text_dsp_obj.cc:1180
#1  0x0812832a in ProcessVariable::do_value_callbacks (this=0x8cca3a8)
    at pv_factory.cc:415
#2  0x08129d8d in EPICS_ProcessVariable::ca_value_callback (args=
      {usr = 0x8cca3a8, chid = 0x8ccb6a0, type = 20, count = 1, dbr =
0x8cfefa8, status = 1}) at epics_pv_factory.cc:300
#3  0x00445b7f in oldSubscription::current ()
#4  0x0043fb58 in netSubscription::completion ()
#5  0x0042403f in cac::eventRespAction ()
#6  0x00428765 in cac::executeResponse ()
#7  0x0043c81e in tcpiiu::processIncoming ()
#8  0x00439fe6 in tcpRecvThread::run ()
#9  0x0015e55b in epicsThreadCallEntryPoint ()
#10 0x001640e9 in start_routine ()
#11 0x00bae98c in start_thread () from /lib/tls/libpthread.so.0
#12 0x00a2f7da in clone () from /lib/tls/libc.so.6
John Sinclair
RE: pv connect/disconnect callbacks Jeff Hill
Prev: RE: orderly shutdown Mark Rivers
Next: RE: pv connect/disconnect callbacks Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: orderly shutdown Jeff Hill
