1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: About: timeout handler of epicsTimer
To: "'EPICS tech-talk'" <[email protected]>
Date: Thu, 12 Jan 2006 10:14:22 +0900
Dear All,
I'm wondering if the following statement about epicsTimer is correct or not.
#Start of the statement
Any handler of epicsTimer runs, when the timer expired, not in an interrupt
context but in a normal task's (thread's) context.
This goes for the case where the iocCore program is running on vxWorks or
RTEMS, or whatever OS supported in Base.
#End of the statement
What I'd like to know is, in other words, if a handler of epicsTimer is
allowed to take semaphores in the handler or not.
I guess the statement is TRUE because I have found an example of a handler
to call printf, in "IOC Application Developer's Guide (Chp.19, Section
10.4)".
Still, I feel I need to confirm it more...
Thanks a lot in advance.
Jun-ichi Odagiri
High Energy Accelerator Research Organization, KEK
Oho 1-1, Tsukuba, Ibaraki, Japan
Re: About: timeout handler of epicsTimer Andrew Johnson
Prev: RE: pv connect/disconnect callbacks Jeff Hill
Next: Re: orderly shutdown Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: Re: About: timeout handler of epicsTimer Andrew Johnson
