Hi :
I have downloaded vxStats-SNS from Epics soft links,but I found I can't
use it for it needs configuration instead of config in Epics base.My Epics
base version is 3.13.8. Can the vxStats-SNS work with base 3.13.8?
I want to know how to use vxstats.Is is an application that what you need
to do is just build it and then download it's database to IOC and use its
medm or edm GUIs?Is it so simple?May I need to make a new application?If I
create a new application and what to know the IOC status,what shall I do?
Now I got a older version vxStats313 from
http://ics-web1.sns.ornl.gov/share/vxStats313.tar.gz,which can work with base
3.13.5. I did following to try to use it with my IOC:
1)I edited Makefile in the top directory to point out EPICS_BASE.
2)I edited config/CONFIG,added CROSS_COMPILER_TARGET_ARCHS=ppc604_long
3)edited config/RELEASE,commented out EPICS_BASE for I have definded it
above in Makefile.And added VX_STATS=/path/to/vxstats
4)edited src/Makefile.Vx,added LIBOBJS
+=$(VX_STATS)/bin/ppc604_long/vxStatsLib
5)Then I gmake it,but I got errors,the result is below:
gmake -C vxStatsApp buildInstall
gmake[3]: Entering directory
`/home/liushu/epicsinstall/vxStats/vxStats/vxStatsApp/src/O.Linux'
../../../config/RULES.Db:159: warning: overriding commands for target
`vxStats.dbd'
/home/liushu/epicsinstall/base3.13.8/base/config/RULES.Host:723: warning:
ignoring old commands for target `vxStats.dbd'
Making template database dependencies
`vxStats.dbd'
gcc -pedantic -O -Wall -D_X86_ -Dlinux -DUNIX -I. -I..
-I../../../include -I../../../include/os/Linux
-I/home/liushu/epicsinstall/base3.13.8/base/include/os/Linux
-I/home/liushu/epicsinstall/base3.13.8/base/include -c ../BSlib.c
../BSlib.c: In function `BSreadUDP':
../BSlib.c:793: warning: pointer targets in passing arg 6 of `recvfrom' differ
in signedness
../BSlib.c: In function `BStransUDP':
../BSlib.c:890: warning: pointer targets in passing arg 6 of `recvfrom' differ
in signedness
../BSlib.c: In function `BSgetBroadcastAddr':
../BSlib.c:973: warning: implicit declaration of function `ioctl'
rm -f libBSlib.a
ar -rc libBSlib.a BSlib.o
ranlib -t libBSlib.a;
Installing library ../../../lib/Linux/libBSlib.a
mkdir ../../../lib
mkdir ../../../lib/Linux
ranlib -t ../../../lib/Linux/libBSlib.a
-I/home/liushu/epicsinstall/base3.13.8/base/include -c ../ioc_stats.c
../ioc_stats.c: In function `read_data':
../ioc_stats.c:31: warning: unused variable `i'
-I/home/liushu/epicsinstall/base3.13.8/base/include -c ../rdbapplist.c
../rdbapplist.c: In function `read_pvs':
../rdbapplist.c:39: warning: unused variable `i'
Expanding dbd
msi -I .. -I /home/liushu/epicsinstall/base3.13.8/base/dbd
../vxStatsInclude.dbd > vxStats.dbd
/bin/sh: line 1: msi: command not found
gmake[3]: *** [vxStats.dbd] Error 127
gmake[3]: Leaving directory
gmake[2]: *** [buildInstall.Linux] Error 2
gmake[2]: Leaving directory
`/home/liushu/epicsinstall/vxStats/vxStats/vxStatsApp/src'
gmake[1]: *** [src.buildInstall] Error 2
gmake[1]: Leaving directory
`/home/liushu/epicsinstall/vxStats/vxStats/vxStatsApp'
gmake: *** [vxStatsApp.buildInstall] Error 2
Can you tell me how to resolve these errors and warnings?
And in the README of the software it's said that" In your main
application's dbd file,include the DBD description:include "vxStats.dbd"".I'm
not clear that what's "main application's dbd file" and where to add the
include description.
Thank you very much!Hope you can help me!
Best regards
Liushu
IHEP
- Re: vxStats Kay-Uwe Kasemir
vxstats for Epics 3.13.8 liushu
<2006>
2025
2026
Re: vxStats Benjamin Franksen
<2006>
2025
2026
