The vxStats we are using in 3.14 uses features of the stringin record
that were only added in 3.14.5 or so. It will not work under 3.13.
Pam Gurd.
> -----Original Message-----
> From: Kay-Uwe Kasemir [mailto:[email protected]]
> Sent: Tuesday, January 17, 2006 8:36 AM
> To: Liu Shu; tech talk
> Subject: Re: vxStats
> On Jan 15, 2006, at 23:08 , Liu Shu wrote:
> > Hi Kay:
> > Thank you for you help.
> > Here I directly use the vxStatsApp for my IOC.Whan I run st.cmd
> > in ioc
> > console.I got the results below:
> > </home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest/st.cmd
> > # Example vxWorks startup file
> > #Following must be added for many board support packages
> > #cd <full path to target bin directory>
> > cd "/home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest"
> > value = 0 = 0x0
> > < cdCommands
> > startup =
> > startup = 0x1ffe8c0: value = 15535248 = 0xed0c90 =
> > prsrv_cast_client + 0x58
> > appbin = "/home/liushu/epicsinstall/vxStats/vxStats/bin/ppc604_long"
> > appbin = 0x1ffe848: value = 15535176 = 0xed0c48 = prsrv_cast_client
> > + 0x10
> > #nfsMount "ics-srv02", "/ade/epics/iocTop/R3.13.7/front_end/3-1","/
> > bootBase"
> > #nfsMount "ics-srv02", "/sns/ADE/home/carl/vxStats/3-1", "/startup"
> > #nfsMount "ics-srv02", "/sns/ADE/home/carl/vxStats/3-1", "/stats"
> > #< ../nfsCommands
> > #ld < /bootBase/bin/ppc603/epicsArchLd.o
> > cd appbin
> > value = 0 = 0x0
> > ld < iocCore
> > value = 33549096 = 0x1ffeb28 = pCaBucket + 0x38
> > ld < seq
> > value = 10908600 = 0xa673b8
> > ld < vxStatsLib
> > value = 10656984 = 0xa29cd8 = ca_server_port + 0x78
> > #epicsArchLd("/bootBase/bin/%s/iocCore");
> > #epicsArchLd("/bootBase/bin/%s/bootBaseLib");
> > #epicsArchLd("/bootBase/bin/%s/seq")
> > #dbLoadDatabase("/bootBase/dbd/bootBase.dbd");
> > iocLogDisable =1
> > iocLogDisable = 0x871634: value = 1 = 0x1
> > #epicsArchLd("/startup/bin/%s/vxStatsLib");
> > cd startup
> > value = 0 = 0x0
> > dbLoadDatabase("../../src/base.dbd")
> > liushu:bash: line 1:
> > /home/liushu/epicsinstall/vxStats/vxStats/iocBoot/ioctest/?value =
> > filename="../db-LexRoutines.c" line1 number=236
> > S_errno = 0x_EBUSY dbRead offffffffpening file .. = /../src/base.dbd
> > pnivxi_func + 0xfe00124f
> > dbLoadDatabase("../../dbd/vxStats.dbd")
> > Error " record type not found" Last token ")"
> > input line: device(stringin,INST_IO,devStringinStats,"VX stats")
> > in: file ../../dbd/vxStats.dbd line 1757
> > in: file ../../dbd/vxStats.dbd line 3514
> > db_parse returned -1
> > value = -1 = 0xffffffff = pnivxi_func + 0xfe00124f
> > dbLoadTemplate("../../src/Db/ioc.substitutions")
> > dbLoadTemplate:
> > error opening sub file ../../src/Db/ioc.substitutions
> > iocInit
> > Star### ting iocInit
> > @(#)EPICS IOC CORE built on Jan 18 2005
> > ### @(#)Version R3.13.8 $2003/02/04 19:59:44$
> > Failed to set time from Unix server
> > value = 0 = 0x0
> > I edited directly the st.cmd of vxStats.The result shows me there's
> > something wrong while loading dbd files.
> Right. Looks like the stringin record, which could be found
> in EPICS base, is not.
> > When I create a new application as what you said.There's no
> > testInclude.dbd
> > file but exampleInclude.dbd.
> That's the one.
> > Then I create the testInclude.dbd and include
> > vxStats.dbd.And need I copy those dbd files into my new
> > applicaions,such as
> > the vxStats.dbd?
> No copy should be necessary.
> By adding something like
> VX_STATS = /path/to/vxStats
> to your apps' configure/RELEASE file
> (config/RELEASE for R3.13),
> the necessary files are found without
> having to copy them into your app.
> > You said "edit my_great_apps/testApp/src/Makefile* to include the
> > library".Do you mean edit the src/Makefile.Vx and add:
> > LIBOBJS += $(VX_STATS)/bin/ppc604_long/vxStatsLib
> > And I should also copy those vxstats db files to my own
> > applications,right?
> Because VX_STATS is defined in RELEASE,
> you can use that variable in
> LIBOBJS += $(VX_STATS)/bin/ppc604_lo....
> without need to copy.
> -Kay
Beam Extracted from SNS Ring Gurd, David P.
octave interface D. Peter Siddons
<2006>
2025
2026
Re: vxStats Kay-Uwe Kasemir
EPICS CA security with the motorRecord? Ernest L. Williams Jr.
<2006>
2025
2026
