Here with BESSY we ar going to install an version of our ADA-Card that
offers in the VME-Bus version 32 temperature channels for PT100 sensors.
This Card is delivered by EuKontrol and is about 2500 EUR, that means 78
EUR/channel. We use here the 3HE-Version with 16 channels per card and
controlled via our embedded controler and the CAN-Bus. There is device
support for EPICS available. A good feature is that this card uses the
same long time stable integrating AD converter as all our ADA-Cards and
so it is best suited in noisy environment with long cables to the
sensor. I want to mention it because we had some trouble with that before.
Regards
Bernhard Kuner
- RE: Cost effective solution for monitoring a large number of temperatures Darrell Nineham
- Driver for Hytec 8601 IP Motor Controller? Doug Murray
- Cost effective solution for monitoring a large number of temperatures Josh Stein
Re: Timestamp record? UPTIME Ralph Lange
<2006>
2025
2026
Re: Cost effective solution for monitoring a large number of temperatures D. Peter Siddons
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
