That's interesting because 3.14.8 builds just fine for Tornado II.
As I recall Tornado II supplies a quite unusual gnu compiler that is
something like gcc 2.72 married with g++ 2.96.
Nevertheless, SUNWspro-6.0.1 and gcc-2.95 are pretty old. I am going to
guess that the issues involved with gcc-2.95 relate to non compliance
with the ANSI/ISO C++ standard.
In principal a patch release should not have forced a compiler change, but
Nevertheless those compilers are quite old, and it might even be that the
upgrade will be worth the effort.
> I also had problems in the linking stage of C++ modules trying to
> use SUNWspro-6.0.1, also in libCom.
Its possible that the issue here is related to either a required purge
for SUNWspro's quirky template database, or that a library (with templates
in it) was built by a different version of SUNWspro. A make rebuild should
prge the template database - as I recall.
Sorry about the hassle.
Jeff
> -----Original Message-----
> From: Steven Hartman [mailto:[email protected]]
> Sent: Friday, January 27, 2006 10:36 AM
> To: EPICS tech-talk
> Subject: C++ compiler versions
> A point of information for others upgrading EPICS versions.
> The latest 3.14 versions of base require a newer C++ compiler
> then previous versions. The old gcc-2.95 which I had
> succesfuly used to compile 3.14.4 and earlier cannot handle
> the C++ code in libCom 3.14.8. I also had problems in the
> linking stage of C++ modules trying to use SUNWspro-6.0.1,
> also in libCom. I switched to gcc-3.4.5 and everything builds fine.
> This is for the host compiler, not cross-compiler. My build
> host is Solaris-8 sparc.
> Steve Hartman
> [email protected] || 919-660-2650
> Duke Free Electron Laser Laboratory
- C++ compiler versions Steven Hartman
enhanced seq record Benjamin Franksen
<2006>
2025
2026
<2006>
2025
2026
