Mark Rivers wrote:
Hi Ron,
Are you aware of the "sseq" record in synApps at the APS?
Here is the beginning of the documentation for it:
"The String Sequence record is similar to the Sequence record, and has
all of its capabilities, but it also can link from either string or
double fields to either string or double fields. The record is used to
trigger the processing of up to ten other records and send values to
those records. It is similar to the fanout record, except that it will
fetch an input value and write an output value instead of simply
processing a collection of forward links. It can also specify one of
several selection algorithms that determine which values to write. It
has no associated device support. Its fields fall into the following
categories: "
The most recent version of the sseq record also has the ability to wait
for processing started by its output links to finish before starting
work on the next link. Each link has a "Wait/noWait" field that can
be modified at run time or at database-configure time.
Tim Mooney ([email protected]) (630)252-5417
Beamline Controls & Data Acquisition Group
Advanced Photon Source, Argonne National Lab.
- RE: enhanced seq record Mark Rivers
Ansi compiler switch Michael Abbott
Re: enhanced seq record Tim Mooney
<2006>
2025
2026
<2006>
2025
2026
