I have an Epics 3.14.7 driver where I found myself wanting to use the
typeof() primitive: as this doesn't appear to be supported as part of ANSI
C++ I found it necessary to defeat the -ansi flag that seems to be set by
default in the Epics build environment.
My question is this: what is the "correct" way to defeat this flag?
Digging through the make system, I discovered that adding the following
two lines to my Makefile does the trick:
CMPLR=LAX
CXXCMPLR=LAX
(As I recall it, all that matters is that the RHS is not the string
STRICT.)
I was wondering *why* this flag is set, but thinking about it I guess the
point is that Epics is intended to be thoroughly cross-platform these
days. My driver most definitely isn't, so I'm happy to lose the flag, but
I'd like to know that I'm not abusing the makefile.
- Re: Ansi compiler switch Emmanuel Mayssat
Re: enhanced seq record Benjamin Franksen
Re: enhanced seq record Tim Mooney
<2006>
2025
2026
Re: enhanced seq record Brian McAllister
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
