On Saturday 28 January 2006 00:52, Chestnut, Ronald P. wrote:
> If you do change the seq record (or make a new one), can you please
> change the behaviour for a "0" delay? Now a new thread is started for
> each (DOL/LNK) pair. If the delay is zero, can you "just do it" in
> the same thread? We found that for some big "explosions" (nested
> SEQs) the task switching dominates the processing time.
I am quite sure the seq record, as it stands, does not start a new
thread for each link group (=DOL/LNK pair). In R3.13 it uses a watchdog
timer to request a callback and in R3.14 it uses callbackRequestDelayed
(which probably is implemented using such a timer; I didn't look at the
sources).
However, it /does/ request a callback for each group, regardless whether
the delay is zero or not, and this can indeed cause unnecessary context
switches. So, yes, I will change this. Adjacent link groups with zero
delay will be processed in a synchronous manner i.e. w/o requesting a
callback.
Thanks for the hint.
Cheers,
Ben
- Re: enhanced seq record Luedeke Andreas
- RE: enhanced seq record Chestnut, Ronald P.
RE: enhanced seq record Mark Rivers
Ansi compiler switch Michael Abbott
<2006>
2025
2026
<2006>
2025
2026
