1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: enhanced seq record
To: Benjamin Franksen <[email protected]>
Cc: [email protected], [email protected]
Date: Mon, 30 Jan 2006 10:05:15 +0100
Benjamin Franksen wrote:
On Saturday 28 January 2006 00:52, Chestnut, Ronald P. wrote:
If you do change the seq record (or make a new one), can you please
change the behaviour for a "0" delay? Now a new thread is started for
each (DOL/LNK) pair. If the delay is zero, can you "just do it" in
the same thread? We found that for some big "explosions" (nested
SEQs) the task switching dominates the processing time.
However, it /does/ request a callback for each group, regardless whether
the delay is zero or not, and this can indeed cause unnecessary context switches. So, yes, I will change this. Adjacent link groups with zero delay will be processed in a synchronous manner i.e. w/o requesting a callback.
Thanks for the hint.
If I remember correctly the "seq" record is 100% asynchronous.
If you specify delays of "0", all DOLn links are supposed to be read at the same time.
How do you want to do this without a callback?
(You need it to place the value into DOn when it's received and then write it to LNKn.)
But of course it would be sometimes useful to have a synchronous process chain,
where the next link is processed after the the previous one completed and then the delay elapsed.
Regards
Andreas
Re: enhanced seq record Benjamin Franksen
Prev: FW: use of SUB record Bruins, Stefan
Next: Re: enhanced seq record Luedeke Andreas
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: enhanced seq record Benjamin Franksen
Next: RE: enhanced seq record Mark Rivers
