1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Ansi compiler switch
To: Michael Abbott <[email protected]>
Cc: [email protected]
Date: Mon, 30 Jan 2006 10:29:27 -0800
If you want to remove the ansi flags put the following line in your
Makefile
CONFORM_CFLAGS_STRICT =
this variable is set = -ansi
by default.
I found this by doing
make -p -n | grep ansi
Emmanuel Mayssat
Lyncean Technologies, Inc.
On Sat, 2006-01-28 at 16:19 +0000, Michael Abbott wrote:
> I have an Epics 3.14.7 driver where I found myself wanting to use the
> typeof() primitive: as this doesn't appear to be supported as part of ANSI
> C++ I found it necessary to defeat the -ansi flag that seems to be set by
> default in the Epics build environment.
> My question is this: what is the "correct" way to defeat this flag?
> Digging through the make system, I discovered that adding the following
> two lines to my Makefile does the trick:
>  	CMPLR=LAX
>  	CXXCMPLR=LAX
> (As I recall it, all that matters is that the RHS is not the string
> STRICT.)
> I was wondering *why* this flag is set, but thinking about it I guess the
> point is that Epics is intended to be thoroughly cross-platform these
> days.  My driver most definitely isn't, so I'm happy to lose the flag, but
> I'd like to know that I'm not abusing the makefile.
Ansi compiler switch Michael Abbott
Prev: Re: FW: use of SUB record Andrew Johnson
Next: Re: enhanced seq record Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Ansi compiler switch Michael Abbott
Next: mallocMustSucceed( 0 ) non-portable Till Straumann
