1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: enhanced seq record
To: Benjamin Franksen <[email protected]>
Cc: [email protected], [email protected]
Date: Mon, 30 Jan 2006 14:13:12 -0500
>>> On 1/28/2006 at 0:25:46 +0100, Benjamin Franksen wrote:
  > (2) No VALn fields. They are of limited use, anyway. Mostly they are
  > needed in order to provide constant input, i.e. if the INPn link is
  > empty. It is true that input links can hold a constant value, too, but
This is a feature that I use frequently.  In fact, we probably have more
seq links that write constants than ones that actually fetch from a link.
I think it makes the intent of the database much clearer if you have this
field rather than putting constants into in-link fields and the storage
overhead seems trivial.
Brian McAllister                                   Senior Software Engineer
[email protected]                      Bates Research & Engineering Center
(617) 253-9537                                                Middleton, MA
enhanced seq record Benjamin Franksen
Prev: Re: Ansi compiler switch Emmanuel Mayssat
Next: Re: enhanced seq record Brian McAllister
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: enhanced seq record Benjamin Franksen
Next: RE: enhanced seq record Chestnut, Ronald P.
