1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ASYN/devGPIB/GPIBCVTIO problem
To: [email protected]
Date: Sat, 04 Feb 2006 20:30:31 -0500
Dear All,
I am confused about what is happening with an Analog In record connected to an ASYN device. In particular this is a devGPIB device with a command of type GPIBCVTIO.
I have created the custom convert routine for this devGPIB GPIBCVTIO command and it appears to work, i.e. I have connected it to an Analog In record and if from the EPICS command line I force the record to process (dbpf aiRecord.PROC 1) and then examine the record's value (dbpr aiRecord) it has correctly retrieved the value from hardware.
However, I next did the following:
I added a dfanout record and an Analog Out record. All three records are passive. I set the DOL of the dfanout record to be the "aiRecord.VAL PP" and OUTA of the dfanout record to be the "aoRecord.VAL PP".
aiRecord -> dfanoutRecord -> aoRecord
I see this behavior when I make dfanoutRecord process:
1) aiRecord processes
3) ao record processes writing the stale value, i.e. the value the aiRecord had before it processed
Note, from ASYN diagnostic output I see #1 happen and then #3 happen.
I infer that in between these the following happened
2) dfanoutRecord retrieved stale data from aiRecord and passed it to aoRecord
So the question is why is the dfanout record retrieving the stale value? It seems it must be that the value is retrieved before the aiRecord is actually done processing.
The last lines of my convert routine are:
       precord->val = floatData;
       precord->udf = 0;
      return 0;
After which the code in devGPIB is responsible for setting PACT = 0.
Have I gone wrong somewhere? Any advice appreciated.
info: EPICS 3.14.7, ASYN 4.2.1, Linux IOC
John Dobbins
Cornell University
Lab for Elementary Particle Physics
Ithaca, NY
Re: ASYN/devGPIB/GPIBCVTIO problem Tim Mooney
Prev: EPICS Collaboration Meeting at APS Ned Arnold
Next: ASYN/devGPIB/GPIBCVTIO problem John Dobbins
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: vlinac broken under MacOS 10.4 Tiger? Geoff Savage
Next: Re: ASYN/devGPIB/GPIBCVTIO problem Tim Mooney
