1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: ArchiveDataServer errors
To: [email protected]
Date: Sat, 11 Feb 2006 15:43:37 +0800
Hello!
    I want to use Archive Data Server.My OS is linux redhat 9 with epics base
3.14.7 and Channelarchive2.6.0.
    According to the manual.pdf.I create directory
/var/www/html/archive/cgi,and copied
ChannalArchiver/XMLRPCServer/O.linux-x86/ArchiveDataServer
/var/www/cgi-bin/xmlrpc/ArchiveDataServer.cgi,and ChannalArchiver's example
serverconfig.xml,serverconfig.dtd to /var/www/cgi-bin/xmlrpc/,and add
following to httpd.conf:
   <Directory "/var/www/html/archive">
    Order Allow,Deny
    Allow from from All
</Directory>
<Directory "/var/www/html/archive/cgi">
    SetEnv "EPICS_TS_MIN_WEST" "-480"
    SetEnv "LD_LIBRARY_PATH"
"/usr/local/lib:/home/liushu/epicsinstall/base3.14.7/base/lib/linux-x86:/home/liushu/epicsinstall/base3.14.7/extensions/lib/linux-x86"
    SetEnv "SERVERCONFIG" "/var/www/cgi-bin/xmlrpc/serverconfig.xml"
    PerlHandler Apache::Registry
    PerlSendHeader On
    Options ExecCGI
</Directory>
   Then I restart httpd by   /etc/rc.d/init.d/httpd restart.I run
ArchiveDataClient.pl -u
http://192.168.20.155/cgi-bin/xmlrpc/ArchiveDataServer.cgi -i
  I got these output:
not well-formed (invalid token) at line 1, column 0, byte 0 at
/usr/lib/perl5/vendor_perl/5.8.0/i386-linux-thread-multi/XML/Parser.pm line
185
   Is there anyone know what's wrong?
   And I have some questions:As I know that ArchiveEngine is web server too,so
I want to know if I start ArchiveEngine I don't need to start httpd,right?And
if I start httpd I don't need to start ArchiveEngine either,right?Or if I use
ArchiveDataServer,which one I need,ArchiveEngine or httpd running?
   Thank you very much!
Best regards
Liushu
Re: ArchiveDataServer errors Kay-Uwe Kasemir
Prev: building EPICS ArchiveViewer Jiro Fujita
Next: Re: ChannelArchiver build error D. Peter Siddons
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: building EPICS ArchiveViewer Jiro Fujita
Next: Re: ArchiveDataServer errors Kay-Uwe Kasemir
