1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: labCA crashes with bad PV
To: "Dennis Nicklaus" <[email protected]>, <[email protected]>
Date: Mon, 13 Feb 2006 11:22:16 -0800
Hi Dennis,
>  > lcaGet ('garbage')
> hangs for a minute or two, then takes down matlab.
> Hitting control-c during the timeout also crashes matlab.
Hmm.  I do the same test on a linux box (2.4.21-37.0.1.ELsmp #1 SMP  i686 athlon i386 GNU/Linux) running epics 3.14.8.1+strtod patch with no problem (see below).  Can you provide more information like what version of epics are you using?
BTW, I like labCA since it lets me set retry count and CA timeout.  The older version of MCA that we have here doesn't allow it.  Plus Till sits next door.
matlab -nojvm
                              < M A T L A B >
                  Copyright 1984-2005 The MathWorks, Inc.
                   Version 7.1.0.183 (R14) Service Pack 3
                              August 02, 2005
  To get started, type one of these: helpwin, helpdesk, or demo.
  For product information, visit www.mathworks.com.
>> lcaGet('garbage')
Initializing labCA Release '$Name:  $'...
Author: Till Straumann <[email protected]>
Ctrl-C handling is disabled (compile-time option)
       ==> Initializing max. timeout to 5. seconds
multi_ezca_get_nelem -  ezcaGetNelem(): could not find process variable : garbageError: Errors encountered...
??? (see above error messages)
Stephanie Allison
Re: labCA crashes with bad PV Kay-Uwe Kasemir
Re: labCA crashes with bad PV Till Straumann
Prev: Re: labCA crashes with bad PV Till Straumann
Next: Re: labCA crashes with bad PV Kay-Uwe Kasemir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: calcout/scalcout record problem in EPICS 3.14.7 Andrew Johnson
