Tim Mooney wrote: The calcout record in EPICS 3.14.7 (and maybe other versions as well -- probably all versions since the record acquired asynchronous device support) has a problem that results in an infinite loop if two calcout records forward link to each other. Ouch: epics> dbpf anjHost:a.TPRO 1 DBR_UCHAR: 1 0x1 epics> dbpf anjHost:a.PROC 1 _main_: Process anjHost:a _main_: Process anjHost:b _main_: Process anjHost:a ... _main_: Process anjHost:a _main_: Process anjHost:b _main_: Process anjHost:a Segmentation fault That was the main thread's stack overflowing, since each forward link involves a recursive call to process the next record in the chain. I agree with your fix, and I've committed the modified calcRecord.c to CVS. Asynchronous device support was added to the calcRecord in R3.14.5 so versions or Base before that release are not susceptible to this problem. There's a patch available that is linked from the R3.14.8 KnownProblems page for anyone who wants to apply it. - Andrew -- There is no S in exprexxo.
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
