I subsequently installed this patch to reduce the scope of the previously
mentioned patch.
Saved settings for D:usershillR3.14.dll_hell_fixepicsbase successfully...
cvs diff -u -wb -i -- ca_client_context.cpp (in directory
D:usershillR3.14.dll_hell_fixepicsbasesrcca)
Index: ca_client_context.cpp
RCS file:
/net/phoebus/epicsmgr/cvsroot/epics/base/src/ca/ca_client_context.cpp,v
retrieving revision 1.9.2.19
diff -c -u -w -b -i -r1.9.2.19 ca_client_context.cpp
cvs diff: conflicting specifications of output style
--- ca_client_context.cpp 17 Feb 2006 22:31:42 -0000 1.9.2.19
+++ ca_client_context.cpp 17 Feb 2006 22:38:36 -0000
@@ -78,7 +78,7 @@
epicsThreadOnce ( & cacOnce, cacOnceFunc, 0 );
epicsGuard < epicsMutex > guard (
*ca_client_context::pDefaultServiceInstallMutex );
if ( ca_client_context::pDefaultService ) {
this->pServiceContext.reset (
@@ -88,6 +88,7 @@
else {
this->pServiceContext.reset ( new cac ( this->mutex, this->cbMutex, *this )
this->sock = epicsSocketCreate ( AF_INET, SOCK_DGRAM, IPPROTO_UDP );
if ( this->sock == INVALID_SOCKET ) {
***** CVS exited normally with code 1 *****
> -----Original Message-----
> From: Margaret Votava [mailto:[email protected]]
> Sent: Friday, February 17, 2006 10:36 AM
> To: [email protected]
> Cc: [email protected]; [email protected]; [email protected]
> Subject: segmentation fault in ca_task_initialize running in Linux
> Dear all,
> We are trying to understand a problem with a DESY/DOOCS utility.
> It generates a segmentation fault within ca_task_initialize (stack trace
> below). The
> epicsMutex ca_client_context::defaultServiceInstallMutex;
> constructor is not being called in all OS platform/Compiler
> combinations.
> In particular, a failing combination is
> Linux 2.6.8-22.0.2/gcc v3.4.3 (red hat)
> Linux 2.6.1/gcc v3.2.3 (red hat)
> but works in Solaris with Solaris compiler.
> We believe that this is a linker problem.
> Has anyone seen before or have any clues of how to fix?
> Thank you kindly,
> Margaret
> ### epics code ###
> (gdb) where
> #0 epicsMutexLock (pmutexNode=0x0)
> at ../../../src/libCom/osi/epicsMutex.cpp:118
> #1 0x006add15 in epicsMutex::lock (this=0x0)
> at ../../../src/libCom/osi/epicsMutex.cpp:211
> #2 0x00ca19cb in ca_client_context (this=0x8d8ce08,
> enablePreemptiveCallback=false) at ../../../include/epicsGuard.h:68
> #3 0x00c88305 in ca_context_create (
> premptiveCallbackSelect=ca_disable_preemptive_callback)
> at ../access.cpp:204
> #4 0x00c8835e in ca_task_initialize () at ../access.cpp:180
> ### doocs code ####
> #5 0x00a3e9f5 in epics_init ()
> at
> /home/votava/smtf/doocs/libs/clientlib/source/clientlib/eq_svr.cc:1928
> #6 0x00a464b5 in EqCall (this=0x8d8cc88)
> at
> /home/votava/smtf/doocs/libs/clientlib/source/clientlib/eq_client.cc:369
> #7 0x00e05837 in __static_initialization_and_destruction_0
> (__initialize_p=1,
> __priority=65535)
> at
> /home/votava/smtf/doocs/libs/dddlib/source/dddlib/panels/device_attr_stubs
> .cc:26
> #8 0x00e05917 in global constructors keyed to ea ()
> at
> .cc:400
> #9 0x00e36819 in __do_global_ctors_aux ()
> from
> /home/votava/smtf/doocs/ups/../ups/../libs/dddlib/ups/../ups/../Linux/lib/
> libddd.so.2.2.5
> #10 0x00d45add in _init ()
> from
> libddd.so.2.2.5
> #11 0x00271318 in _dl_init_internal () from /lib/ld-linux.so.2
> #12 0x002657ff in _dl_start_user () from /lib/ld-linux.so.2
- Re: segmentation fault in ca_task_initialize running in Linux Margaret Votava
- segmentation fault in ca_task_initialize running in Linux Margaret Votava
genSub tutorial needed Dennis Nicklaus
Re: genSub tutorial needed Tim Mooney
<2006>
2025
2026
RE: segmentation fault in ca_task_initialize running in Linux Jeff Hill
<2006>
2025
2026
