the genSub records? I've read the record reference manual entry for them and I still don't get it. Here's what I want to do: 1. Have a function which would create two arrays, I and Q, of N points each, using several input parameters (values of other PVs) whenever any of the other PVs is set. 2. Copy these 2 arrays out to two separate VME memory address locations (I'm copying an array to an array of addresses, not each-element-in-the-array-to-the-same-address as in a FIFO). 3. Process other records as with an FLNK link. This sounds simple enough, but it is beyond my meager EPICS knowledge. Thanks! Dennis
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
