Mark,
I'm actually using an SBS IP-AD16SS but I hope I can just modify what you've
done. Thanks. (Also thanks to Tim Mooney and Bob Dalesio for responding.)
John Dobbins
Mark Rivers wrote:
John,
I do exactly what you are trying to do with the Ip330 16-channel ADC. Is that the Industry Pack ADC that you are using?
I put my data in mca records, rather than waveform records, but the principle is identical. The Ip330 generates interrupts at a few kHz, and I put the 16 values into 16 MCA records. The device support will do averaging, so that I can store at new point in the MCA record every reading, or average N readings before storing the new point.
The current implementation of this uses an "asyn" driver, using the callback mechanism provided by asyn. There is device support for mca records (waveforms), ai records (averaging ADC), and epid records (for fast PID feedback).
The source is on the Web at
http://cars.uchicago.edu/software/epics
in the mca and ip330 modules there.
The current version is for 3.14.8.
There is still 3.13 support available, and in fact I just noticed that the documentation is still for 3.13. The 3.13 version uses the Message Passing Facility (MPF), rather than asyn.
Sent: Thu 2/23/2006 11:40 AM
To: EPICS Tech-Talk
Subject: Looking for Application Example
Dear All,
I want to create the following application in EPICS. I have a sixteen
channel industry pack ADC that I will be using in a VME crate with an
MVME162. EPICS version 3.13.10. I want to read the ADC at ~ 1.4 kHz and
record waveforms lasting 5 to 10 seconds. As this is faster then I can
imagine record processing taking place I assume I need to create device
support that creates a task which runs at 1.4 kHz, maintains data
buffers and periodically lets a waveform record (?) know that more data
is available (I'd like to be able to see some of the data before the
total acquisition is complete.)
Does anyone have code for something resembling this that I could look at?
John Dobbins
Research Support Specialist
Lab for Elementary Particle Physics
Cornell University
- RE: Looking for Application Example Mark Rivers
RE: EZCA win32 Jeff Hill
Re: Looking for Application Example Steven Hunt
<2006>
2025
2026
edm and Linux window manager Rolf Keitel
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
