Hi John,
I often do this sort of thing, in a simple way, using just a waveform
and ai record looking at the same hardware.
I my case I use a Hytec 8401 industry pack but I expect your adc has
similar device support.
Firstly I would configure the adc to use an external clock (or a 1 or 2
KHz internal clock if you don't need exactly 1.4 KHz).
A waveform record (NELM=5000) processing for instance every 5 seconds
will return the last 5000 samples of data from the on-board circular
buffer.
A ai record processing at say 10Hz can in parallel read the same data at
a faster rate (it can also return an average of many samples to reduce
noise and give higher - 18 bit - resolution).
The hardware and device support also allows many more options - for
instance the buffer can be set to fixed length rather that circular, and
acquisition can be started using an external trigger, the waveform
record (SCAN=I/O Intr) will be processed when the buffer is full.
Email me directly if you want me to send you an example db file.
Steve Hunt
On Thu, 2006-02-23 at 18:40 +0100, John Dobbins wrote:
> Dear All,
> I want to create the following application in EPICS. I have a sixteen
> channel industry pack ADC that I will be using in a VME crate with an
> MVME162. EPICS version 3.13.10. I want to read the ADC at ~ 1.4 kHz and
> record waveforms lasting 5 to 10 seconds. As this is faster then I can
> imagine record processing taking place I assume I need to create device
> support that creates a task which runs at 1.4 kHz, maintains data
> buffers and periodically lets a waveform record (?) know that more data
> is available (I'd like to be able to see some of the data before the
> total acquisition is complete.)
> Does anyone have code for something resembling this that I could look
> at?
> Thanks,
> John Dobbins
> Research Support Specialist
> Lab for Elementary Particle Physics
> Cornell University
- Looking for Application Example John Dobbins
Re: Looking for Application Example John Dobbins
RE: EZCA win32 URIOT Didier DAPNIA
<2006>
2025
2026
Re: Looking for Application Example Tim Mooney
RE: Looking for Application Example Mark Rivers
<2006>
2025
2026
