1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: XYCOM XY566 Single Ended Mode with EPICS 3.14 and Power PC
To: Simon Rees <[email protected]>
Cc: [email protected]
Date: Wed, 01 Mar 2006 08:48:56 +0100
Simon Rees wrote:
Dear all
Just wondering whether anyone has got an XYCOM XVME-566 card
working in single-ended mode with a Power PC MVME5100 under
EPICS R3.14(.8.2) ?
I seem to be having two problems:
1.  I am puzzled why the reported raw value of my ai test record
   is stuck at 4095 when there is no input signal attached to
   the card.  I have checked the numerous switch/link settings
   exhaustively but can't see anything obviously wrong.
   2.  After a WARM reboot the following error message is issued:
PV: ppcdev:my_ai_record devAiXy566Se (init_record) ai_xy566_driver error
        On subsequent COLD reboots the card is successfully recognised.
   The documentation for the card refers to the need to disable
   the Sequence Controller Enable Bit (Bit 8) in the Control/Status
   Register before performing a warm reset. I can't see any support
   for this in the driver (although I can see support for disabling
   some interrupts).
Many thanks for any light anyone can shed
Simon Rees
Isaac Newton Group of Telescopes
I believe this has nothing to do with EPICS version and processor used. Try to terminate the inputs with 50 Ohm and see what you read then. The single ended inputs go to high if nothing is connected.
Burkhard
XYCOM XY566 Single Ended Mode with EPICS 3.14 and Power PC Simon Rees
Prev: XYCOM XY566 Single Ended Mode with EPICS 3.14 and Power PC Simon Rees
Next: IDL MCA and CA through firewalls?? Antonino Miceli
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
