CORRECTION:
Sorry, I had to wait about 20 minutes (not 7) to boot with the unpatched
wu-ftpd. I don't know if my mvme-177 bootroms are flash-able, or how to do
that.
-ps
-----Original Message-----
Sent: Wednesday, March 01, 2006 3:56 PM
To: [email protected]
Subject: RE: vxWorks and ProFTPD
Dale,
When I upgraded to Solaris 9, the wu-ftpd 2.6.2 server (that comes with Sol9)
required tighter adherence to the RFC-specified protocols. My mvme-177
vxWorks BSP's implementation of the ftp protocol does not strictly adhere to
the specifications. In my case I had to wait almost 7 minutes to boot. If
you want I can send you a document explaining how to patch the wu_ server to
support so-called 'broken-clients', which then boots the IOC in the normal
fashion.
Paul Sichta
Princeton Plasma Physics Laboratory
609-243-3477
Sent: Wednesday, March 01, 2006 2:52 PM
Subject: vxWorks and ProFTPD
I'm having a bit of an issue trying to get tornado 2.02 to boot from
a RAID network storage appliance (ReadyNAS from Infrant) running
ProFTPD v.1.2.9 under a version of Linux. The problem is that
downloading the boot image takes around 6-7 minutes. Downloading the
script file happens normally, in a couple of seconds. I've found no
diagnostics in the server log other than statements showing that the
first session opens and closes ~7 minutes later, and the second
session opens and closes in a few seconds. This appears to be
different than the situation in which the second file or a second
reboot takes a long time because of inability to reuse the port. My
problem happens first time, every time. I've connected to the server
with various mac, windows and solaris clients w/ no problems. I have
however seen a problem w/ WS_FTP v4.50 that could be similar. I found
some info mentioning slow connections due to a reverse DNS lookup by
ProFTPD, but the vendor sent a config file patch that supposedly
prevents this reverse lookup, with no effect. I would appreciate any
suggestions or info as to whether anyone has successfully used either
this particular NAS or ProFTPD in other environments.
thanks
dale brewe
Dale L. Brewe
PNC-CAT/Argonne National Laboratory
ph: 630 252 0582 fax: 630 252 0580
Mail:
Bldg 435E sector 20
9700 S. Cass Ave.
Argonne, IL 60439
RE: vxWorks and ProFTPD Paul Sichta
Re: vxWorks and ProFTPD Dale L. Brewe
<2006>
2025
2026
Gateway error Leicester, PJ (Pete)
<2006>
2025
2026
