1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: vxWorks and ProFTPD
To: <[email protected]>
Date: Wed, 1 Mar 2006 15:56:08 -0500
Dale,
When I upgraded to Solaris 9, the wu-ftpd 2.6.2 server (that comes with Sol9)
required tighter adherence to the RFC-specified protocols. My mvme-177
vxWorks BSP's implementation of the ftp protocol does not strictly adhere to
the specifications.  In my case I had to wait almost 7 minutes to boot.  If
you want I can send you a document explaining how to patch the wu_ server to
support so-called 'broken-clients', which then boots the IOC in the normal
fashion.
Paul Sichta
Princeton Plasma Physics Laboratory
609-243-3477
-----Original Message-----
Sent: Wednesday, March 01, 2006 2:52 PM
To: [email protected]
Subject: vxWorks and ProFTPD
I'm having a bit of an issue trying to get tornado 2.02 to boot from
a RAID network storage appliance (ReadyNAS from Infrant) running
ProFTPD v.1.2.9 under a version of Linux. The problem is that
downloading the boot image takes around 6-7 minutes. Downloading the
script file happens normally, in a couple of seconds. I've found no
diagnostics in the server log other than statements showing that the
first session opens and closes ~7 minutes later, and the second
session opens and closes in a few seconds. This appears to be
different than the situation in which the second file or a second
reboot takes a long time because of inability to reuse the port. My
problem happens first time, every time. I've connected to the server
with various mac, windows and solaris clients w/ no problems. I have
however seen a problem w/ WS_FTP v4.50 that could be similar. I found
some info mentioning slow connections due to a reverse DNS lookup by
ProFTPD, but the vendor sent a config file patch that supposedly
prevents this reverse lookup, with no effect. I would appreciate any
suggestions or info as to whether anyone has successfully used either
this particular NAS or ProFTPD in other environments.
thanks
dale brewe
  Dale L. Brewe
  PNC-CAT/Argonne National Laboratory
  ph: 630 252 0582         fax: 630 252 0580
  Mail:
  Bldg 435E sector 20
  9700 S. Cass Ave.
  Argonne, IL 60439
Prev: Re: vxWorks and ProFTPD Andrew Johnson
Next: RE: vxWorks and ProFTPD Paul Sichta
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: drvAscii codes Ian A Smith
