1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: drvAscii codes
To: [email protected]
Date: Fri, 03 Mar 2006 10:09:55 +0000
I'm trying to get epics to talk to an (awkward) piece of equipment. It requires: "[stx]command[etx][cr][lf]", where of course, [stx] and [etx] are ascii 2 and 3.
I've succeeded in puting the [etx] on the end of lines but I get the literal string "\002" instead of [stx] at the start, so I'm looking for help!
The record which successfully puts [etx] in line termination is:
record(stringout,"scu2CCS:shutter:coms:txCmd") {
    field(DESC,"string output record")
    field(SCAN,"Passive")
    field(PINI,"YES")
    field(PHAS,"0")
    field(EVNT,"0")
    field(DTYP,"Ascii SIO")
    field(DISV,"1")
    field(SDIS,"0.000000000000000e+00")
    field(DISS,"NO_ALARM")
    field(PRIO,"LOW")
    field(FLNK,"0.000000000000000e+00")
    field(VAL,"\003\r\n")
    field(DOL,"\003\r\n")
    field(OMSL,"closed_loop")
    field(OUT,"@/pty/shutterM <writeCmt %s>")
    field(SIOL,"0.000000000000000e+00")
    field(SIML,"0.000000000000000e+00")
    field(SIMS,"NO_ALARM")
    field(IVOA,"Continue normally")
    field(IVOV,"")
and the record which fails to put [stx] in the command line is:
record(stringin,"scu2CCS:shutter:test") {
    field(DESC,"string input record")
    field(SCAN,"10 second")
    field(PINI,"NO")
    field(PHAS,"0")
    field(EVNT,"0")
    field(DISV,"1")
    field(PRIO,"LOW")
    field(VAL,"string")
    field(INP,"@/pty/shutterM <\002SUI><%s>")
TIA
Ian A Smith               Telephone: +44 (0) 131 668 8255
Royal Observatory         Fax:       +44 (0) 131 668 8314
Blackford Hill            Web:       http://www.roe.ac.uk/
Edinburgh
EH9 3HJ
UK
vxWorks and ProFTPD Dale L. Brewe
Re: vxWorks and ProFTPD Andrew Johnson
Re: vxWorks and ProFTPD Dale L. Brewe
Prev: Re: vxWorks and ProFTPD Andrew Johnson
Next: Gateway error Leicester, PJ (Pete)
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Next: RE: vxWorks and ProFTPD Paul Sichta
