1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: calcPerform expressions: 'NOT' operator
To: Tech Talk <[email protected]>
Date: Fri, 03 Mar 2006 14:56:15 -0600
Summary: I am working on changes and enhancements to the calcPerform code in R3.14, and am considering making a change that will alter the behaviour of expressions that use the 'NOT' operator in future versions of EPICS. Please respond if this change will adversely affect your site, i.e. if you actually make heavy use of the 'NOT' operator (as against the related '-', '~' or '!' operators).
The libCom calc subsystem is used by the calc and calcout records, Channel Access security module, MEDM and probably some other client tools to evalutate expressions. It provides separate operators for doing logical and bitwise operations, for example '&' is a bitwise AND while '&&' is a logical AND. The operator 'AND' is also supported as a synonym for the bitwise operator, and has parallel operators 'OR' and 'XOR'.
When it comes to the unary NOT operations however, the operator 'NOT' does not match the bitwise '~' not operator, but instead performs a NEGATE operation like the unary minus operator. This obscure behavior is documented in the Record Reference manual.
The current 'NOT' operator dates back to a time when the expression parser only supported the use of '-' as a binary subtraction operator, and for some reason the keyword 'NOT' was picked for the unary minus operator. However the ability to use '-' for unary minus was added by Janet in R3.12.0beta7 about 11 years ago, so I'm now proposing to change 'NOT' to be a synonym for the bitwise operator '~'.
Please reply if you object to this change because your site uses 'NOT' in a significant number of CALC expressions of a 3.14 database or Access Security configuration file.
To reward anyone who was interested enough to read to the bottom of this message, here's what I'm up to: I've been significantly improving the error checking and reporting from the expression parser, and have added an assignment operator ':=' and expression terminator ';'. A single CALC record can now return multiple results, although it is still subject to the 40 character limit for the expression string.
- Andrew
There is no S in exprexxo.
RE: calcPerform expressions: 'NOT' operator Jeff Hill
Re: calcPerform expressions: 'NOT' operator Tim Mooney
Prev: RE: Gateway error Jeff Hill
Next: RE: calcPerform expressions: 'NOT' operator Redman, Russell
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: drvAscii codes Al Honey
Next: RE: calcPerform expressions: 'NOT' operator Jeff Hill
