Not directly relevant to your message, but if you are working on the
calcPerfom routines, can I remind you of the efforts that Tim Mooney and
I (mostly Tim) put in a couple of years ago to add variable argument
lists to the MAX and MIN operators? The ability to evaluate expressions
like MIN(H,MAX(A,B,C,D,E,F)) is really handy, especially when struggling
with the 40 character limit.
Tim also added binary max and min operators, >? and <?, but as I recall
the parsing of these operators conflicted with expressions like A?B. I
think that this compatability issue discouraged any effort to include
the changes in the standard EPICS versions. However, I think the MAX
and MIN operators were OK.
Just a suggestion in case you are interested,
Russell O. Redman
-----Original Message-----
Sent: Friday, March 03, 2006 12:56 PM
To: Tech Talk
Subject: calcPerform expressions: 'NOT' operator
Summary: I am working on changes and enhancements to the calcPerform
code in R3.14, and am considering making a change that will alter the
behaviour of expressions that use the 'NOT' operator in future versions
of EPICS. Please respond if this change will adversely affect your
site, i.e. if you actually make heavy use of the 'NOT' operator (as
against the related '-', '~' or '!' operators).
The libCom calc subsystem is used by the calc and calcout records,
Channel Access security module, MEDM and probably some other client
tools to evalutate expressions. It provides separate operators for
doing logical and bitwise operations, for example '&' is a bitwise AND
while '&&' is a logical AND. The operator 'AND' is also supported as a
synonym for the bitwise operator, and has parallel operators 'OR' and
'XOR'.
When it comes to the unary NOT operations however, the operator 'NOT'
does not match the bitwise '~' not operator, but instead performs a
NEGATE operation like the unary minus operator. This obscure behavior
is documented in the Record Reference manual.
The current 'NOT' operator dates back to a time when the expression
parser only supported the use of '-' as a binary subtraction operator,
and for some reason the keyword 'NOT' was picked for the unary minus
operator. However the ability to use '-' for unary minus was added by
Janet in R3.12.0beta7 about 11 years ago, so I'm now proposing to change
'NOT' to be a synonym for the bitwise operator '~'.
Please reply if you object to this change because your site uses 'NOT'
in a significant number of CALC expressions of a 3.14 database or Access
Security configuration file.
To reward anyone who was interested enough to read to the bottom of this
message, here's what I'm up to: I've been significantly improving the
error checking and reporting from the expression parser, and have added
an assignment operator ':=' and expression terminator ';'. A single
CALC record can now return multiple results, although it is still
subject to the 40 character limit for the expression string.
- Andrew
There is no S in exprexxo.
calcPerform expressions: 'NOT' operator Andrew Johnson
RE: calcPerform expressions: 'NOT' operator Jeff Hill
<2006>
2025
2026
Re: calcPerform expressions: 'NOT' operator Tim Mooney
RE: calcPerform expressions: 'NOT' operator Chestnut, Ronald P.
<2006>
2025
2026
