1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice 2
To: [email protected]
Date: Sat, 11 Mar 2006 00:22:37 +0100
On Thursday 09 March 2006 16:05, Dirk Zimoch wrote:
> StreamDevice Version 2.0 is released now.
> http://epics.web.psi.ch/software/streamdevice/
> It requires R3.14.6 or higher (recommended: R3.14.8.2) and asynDriver
> 4-3 or 4-4.
Hi Dirk
many thanks for this work. I will use this (together with asyn) as a
replacement for devCommonGpib-style device supports ASAP.
I have one question: the docs say that readback from devices for output
records (for bumpless reboot) is done synchronously, blocking iocInit
until all such readbacks have completed. There may be situations where
this is the right aproach. However, there are others, where one would
wish to have the readback to proceed asynchronously, for instance if
there are a lot of such records on an IOC.
In our MultiCAN package we do this by letting init_record 'fake' the
first phase of asynchronous processing. That is, init_record starts
readback, sets PACT and arranges for a special kind of process callback
that lets processing complete with a read (instead of the normal write)
operation.
Would it be very difficult to enable such behavior (optionally, the
synchronous version remaining the default) for StreamDevice, too? Would
you accept a patch that implements this?
The StreamDevice docs mention the interaction with PINI flag. I think
the best solution is to enable readback on startup only if PINI
is /not/ set. Reading back from teh device hardly makes sense if the
first thing you are going to do is overwrite the value with something
else. OTOH, if PINI is not set, then doing a readback on startup will
at least not do any harm.
Ben
There are three kinds of programmers: those who make off by one errors,
and those who don't.
Re: StreamDevice 2 Dirk Zimoch
Prev: Re: segmentation fault in ca_task_initialize running in Linux Margaret Votava
Next: RE: asynDriver/asynGpib LYNCH, Damien
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: StreamDevice 2 Dirk Zimoch
Next: Re: StreamDevice 2 Dirk Zimoch
