1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice 2
To: Benjamin Franksen <[email protected]>
Cc: [email protected]
Date: Mon, 13 Mar 2006 10:48:32 +0100
Hi Ben
Benjamin Franksen wrote:
I have one question: the docs say that readback from devices for output records (for bumpless reboot) is done synchronously, blocking iocInit until all such readbacks have completed. There may be situations where this is the right aproach. However, there are others, where one would wish to have the readback to proceed asynchronously, for instance if there are a lot of such records on an IOC.
In our MultiCAN package we do this by letting init_record 'fake' the first phase of asynchronous processing. That is, init_record starts readback, sets PACT and arranges for a special kind of process callback that lets processing complete with a read (instead of the normal write) operation.
Would it be very difficult to enable such behavior (optionally, the synchronous version remaining the default) for StreamDevice, too? Would you accept a patch that implements this?
If you have many of such records, iocInit may take a long time. Initializing the records synchronously was the easiest way to ensure that all initialized records have got their values before any record processes and can ask for that value. (This is something I do not want to give up.)
I'll try to implement a more clever way to do this, initializing the records asyncronously ("in parallel") and then waiting in iocInit until all records have competed before the scan tasks start. If you send me some code example from your MultiCAN package, I will have a look at it.
The StreamDevice docs mention the interaction with PINI flag. I think the best solution is to enable readback on startup only if PINI is /not/ set. Reading back from teh device hardly makes sense if the first thing you are going to do is overwrite the value with something else. OTOH, if PINI is not set, then doing a readback on startup will at least not do any harm.
There is a conceptional difference between the @init handler and PINI. The first is initialization of the record (called from init_record()), the second is initialization of the device (called from process()).
Readback on startup is enabled if and only if an @init handler is defined (that reads the value). If you don't want a readback, don't define an @init handler. If you don't want to overwrite the value in the device, don't set PINI. I leave it to the user to decide if PINI after @init makes sense or not. Why should StreamDevice try to be smarter than the user? BTW: Maybe @init handlers do other stuff than readback, e.g. initializing the hardware. There is no simple way how StreamDevice can find out what @init actually does.
Dirk
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax   +41 56 310 4413
StreamDevice 2 Dirk Zimoch
Re: StreamDevice 2 Benjamin Franksen
Prev: Releasing EPICS driver for Libera Michael Abbott
Next: Re: asynDriver/asynGpib Marty Kraimer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: StreamDevice 2 Benjamin Franksen
Next: CA beacon routing problem Evgeniy Tikhomolov
