Laznovsky, Michael wrote:
Hi- how can I get strings in & out of subroutine records?
It appears that the sub record tries to convert all its inputs
to "double" before calling the user function, and complains if it
fails. All I want is to read/write actual strings from inside
the function.
Right, you can't use the INP/OUT fields of a sub record for anything
other than doubles. As Andy Foster has said you could use a genSub
record, or if you only need one string you could use the psub->desc
field of the regular subroutine record (although it's only 28 characters
long). You could also consider writing your code as device support for
the stringin and/or stringout records.
- Andrew
There is no S in exprexxo.
- stringin/out <-> sub record ? Laznovsky, Michael
RE: gateway enum writes Mark Rivers
Re: gateway enum writes Kate Feng
<2006>
2025
2026
Re: stringin/out <-> sub record ? Martin L. Smith
SIGs Dalesio, Leo `Bob`
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
