1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: gateway enum writes
Cc: "Kenneth Evans, Jr." <[email protected]>, [email protected]
Date: Thu, 30 Mar 2006 11:02:01 -0500
Mark Rivers wrote:
For what it's worth, the problem with the scaler record's CNT field behaving strangely with medm is seen with medm running on Linux,
As what I stated, the problem does not happen to all the  Linux
platforms.  It  always happened only on my RedHat7.3 Linux
notebook. We have never seen this problem on the other Linux
platforms.
but not on Windows.  I don't know if the difference is dues to differences in CA or XWindows on these platforms.
Probably not.  My  tests were based on the same IOC
accessed via various  versions of Linux PCs running MEDM
Version 3.0.3.
Kate
But I don't think this behaviour is necessarily related to the caPutCallback problem with the gateway.  I think the medm behavior here may be caused by a caPut to the CNT field rapidly causing a change in the CNT field that medm somehow loses track of?
Sent: Thu 3/30/2006 9:12 AM
To: Kenneth Evans, Jr.
Cc: [email protected]
Just a comment about the Joerger scaler/MEDM
problem, which I do not think is related to gateway.
Kenneth Evans, Jr. wrote:
	     On looking at the original message I can guess that you are using a
	Joerger scaler.  The Joerger scaler does not play well with channel access.
	It does not work well with MEDM, either on Solaris or Linux.  I investigated
	this some time ago, to the extent I was convinced it was not MEDM.  The beam
	line people that were using it at that time did not have enough expertise to
	determine the real cause of the problem.  The same problem has appeared at
	various sites since.
	     My recollection is that the workaround for the Joerger scaler is to
	push the buttons alternately to get it to be done.  You can also have two
	screens and use the buttons on both of them.  You'll have to experiment.
I observed the above Joerger scaler/MEDM problem on my
RedHat7.3 Linux PC, but not on the RedHat9.0 Linux PC,
and other Debian Linux PCs in the beamlines.  In all
cases, the IOCs are run under EPICS3.14.x/RTEMS.
Kate
RE: gateway enum writes Mark Rivers
Prev: Re: stringin/out <-> sub record ? Andrew Johnson
Next: SIGs Dalesio, Leo `Bob`
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: gateway enum writes Mark Rivers
Next: RE: gateway enum writes Mark Rivers
