Emmanuel Mayssat wrote:
John,
Create you own menuScan.dbd in your ${MY_DIRECTORY}/dbd directory.
Then edit the makefile in your driver source and add a new USR_DBDFLAGS
directive.
# Used by dbExpand to look for dbd files
USR_DBDFLAGS += -I ${MY_DIRECTORY}/dbd
USR_DBDFLAGS += -I ${EPICS_BASE}/dbd
Actually you don't even need to do this, just add this line to your
xxxApp/src/Makefile in the directory where you put the modified
menuScan.dbd file:
DBD += menuScan.dbd
This will ensure that the file gets installed to $(TOP)/dbd. In the DBD
file expansion process the directory $(TOP)/dbd is always searched
before $(EPICS_BASE)/dbd so it will find your version first.
Make sure that you do a 'make rebuild' after adding that line though.
- Andrew
There is no S in exprexxo.
- adding a scan period john sinclair
- Re: adding a scan period Andrew Johnson
- Re: adding a scan period Emmanuel Mayssat
scan periods john sinclair
<2006>
2025
2026
<2006>
2025
2026
