Kay,
The Name returned is "1769-L35E Ethernet Port". Details below.
John
Data Received (92 bytes):
00000000 6F 00 44 00 4C 71 02 0A 00 00 00 00 46 75 6E 73 - o.D.Lq......Funs
00000010 74 75 66 66 00 00 00 00 00 00 00 00 00 00 02 00 - tuff............
00000020 00 00 00 00 B2 00 34 00 8E 00 00 00 17 31 37 36 - ......4......176
00000030 39 2D 4C 33 35 45 20 45 74 68 65 72 6E 65 74 20 - 9-L35E Ethernet
00000040 50 6F 72 74 00 00 00 00 00 00 00 00 01 00 EB CD - Port............
00000050 1E 00 00 00 0E 02 0E 01 0E 00 0E 00 - ............
EncapsulationHeader:
UINT command = 0x6F (SendRRData)
UINT length = 68
UDINT session = 0x0A02714C
UDINT status = 0x00000000 (OK)
USINT context[8]= 'Funstuff'
UDINT options = 0x00000000
Received RR Data
UDINT interface handle 0
UINT timeout 0
UINT count (addr+data) 2
UINT address_type 0x0 (UCMM)
UINT address_length 0
UINT data_type 0xB2 (Unconnected Message)
UINT data_length 52
MR_Response:
USINT service = 0x8E (Response to Get_Attribute_Single)
USINT reserved = 0x00
USINT status = 0x00 (Ok)
USINT ext. stat. size = 0
Data (net format) =
00000000 17 31 37 36 39 2D 4C 33 35 45 20 45 74 68 65 72 - .1769-L35E Ether
00000010 6E 65 74 20 50 6F 72 74 00 00 00 00 00 00 00 00 - net Port........
00000020 01 00 EB CD 1E 00 00 00 0E 02 0E 01 0E 00 0E 00 - ................
Kay-Uwe Kasemir wrote:
On Apr 6, 2006, at 12:17 , Carl Cork wrote:
According to CIP Protocol Ed. 2.2 (Dec 2005), C-5.2.6 String Encodings:
a SHORT_STRING consists of a 1-Byte character count followed by count
characters (1 byte per character). Therefore, the Product Name attribute
field should have a maximum length of 33 bytes.
John Dobbins wrote:
Kay,
Actually, it looks like there may be another interpretation. The
product name is defined as (DeviceNet?) type SHORT_STRING. I don't
know where this is defined but it looks like it may be: "a single
byte length field and 'n' data bytes".
In which case the Product Name is being returned inside a longer
field. The Product Name is less than 32 characters but the data field
it is returned in is longer than 32 bytes.
EIP_check_interface() rejects the product name because is finds the
length of the data returned >32, even though the string length is
less than 32.
You're right in that the length check used the data package size,
and the package contains
BYTE length
BYTE name[length]
So the actual name length is one less than the package byte count.
Then it's copied into a C char name[] with an added final '\0',
which adds another byte.
Strictly speaking, I need to check the length byte,
instead of silently expecting it to contain (package length-1).
OK, I'll do that.
Now where are we with CompactLogix?
What product name does it return?
How long is it? BTYE 51 + 51 characters?
Or does it return
BYTE length=32
char name[32]
... plus more junk to get a package of 52 bytes
-Kay
- Re: Ethernet/IP Device Support and CompactLogix Kay-Uwe Kasemir
- Ethernet/IP Device Support and CompactLogix John Dobbins
- Re: Ethernet/IP Device Support and CompactLogix John Dobbins
- Re: Ethernet/IP Device Support and CompactLogix Carl Cork
<2006>
2025
2026
<2006>
2025
2026
