Hi Max,
There is a pure database solution (no C code) for the 8752 in the
synApps "ip" module, called picoMotor.db It uses asyn records for the
I/O, so it should work with serial or TCP/IP. It uses "transform" and
"scalcout" records, which are from the "calc" module in synApps.
> -----Original Message-----
> From: Maximilien J. Collon [mailto:[email protected]]
> Sent: Wednesday, April 12, 2006 6:10 AM
> To: [email protected]
> Subject: NewFocus 8752
> Hi,
> I was wondering if somebody has developed EPICS device support for a
> NewFocus Picomotor Ethernet controller 8752? We would like to talk via
> tcp/ip and this unit to 6 picomotors, which are attached to it. As an
> alternative we could also use RS232 communications with the 8752.
> Any help would be greatly appreciated.
> Thanks and with kind regards,
> Max
> Maximilien J. COLLON
> cosine Research BV :: Tel +31 71 528 49 69
> Niels Bohrweg 11 :: Fax +31 71 528 49 63
> NL-2333 CA Leiden :: Web http://cosine.nl
Re: NewFocus 8752 Joe Sullivan
AW: NewFocus 8752 Maximilien J. Collon
<2006>
2025
2026
Re: AlarmHandler - filtering vs. HYST Brian McAllister
<2006>
2025
2026
