This looks as if StreamDevice does not know about asyn.
Try: dbior "stream"
Does it report someting like this?
Driver: stream
StreamDevice 2.0 built Apr 19 2006 09:25:46
registered bus interfaces:
DebugInterface
AsynDriverInterface
If AsynDriverInterface is not listed, have you accidentally commented
out the bus interface in CONFIG_STREAM?
Unfortunately, with asyn 4-5, you still have to specify ASYN_VERS=4-3 in
CONFIG_STREAM (I will fix that later).
Do you load the munched library? On vxWorks, this is required to run the
C++ constructors which register the bus interfaces and other things.
Dirk
Porter, Rodney R. wrote:
I am running EPICS 3.14.8.2, tornado 2.2, asyn 4.5, streamDevice 2.0 on
mvme167 and ppc2304 CPUs with a serial port server. I am able to
connect to the serial devices with the generic serial record, but
streamDevice gives me a connection error. asynReport() shows the port
disconnected until I connect with the generic serial record or turn on
the trace masks. Am I missing something in the initialization, or is
there a problem with the code.
Rodney Porter
Sr. Scientific Programmer
Data Aquisition & Detector Systems
Intense Pulsed Neutron Source
Argonne National Laboratory
9700 So. Cass Ave
Argonne, IL 60439 USA
Ph. (630) 252-7151
E-mail: [email protected] <mailto:[email protected]>
IPNS website: www.pns.anl.gov <http://www.pns.anl.gov>
Most of boot output follows:
____________________________________________________________________________
dbLoadDatabase("$(TOP)/dbd/ancVx.dbd")
interrupt:
ei0: reset
value = 0 = 0x0
ancVx_registerRecordDeviceDriver(pdbbase)
value = 0 = 0x0
# Disable Logging
iocLogDisable = 1
iocLogDisable = 0x41e738: value = 1 = 0x1
# Asyn Configuration.
drvAsynSerialPortConfigure("L0","/tyCo/1",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L7","192.168.1.251:2007",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L8","192.168.1.251:2108",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L9","192.168.1.251:2009",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L10","192.168.1.251:2010",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L11","192.168.1.251:2011",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L12","192.168.1.251:2012",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L13","192.168.1.251:2013",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L14","192.168.1.251:2014",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L15","192.168.1.251:2015",0,0,0)
value = 0 = 0x0
drvAsynIPPortConfigure("L16","192.168.1.251:2016",0,0,0)
value = 0 = 0x0
# StreamDevice Configuration.
epicsEnvSet("STREAM_PROTOCOL_PATH", "$(TOP)/protocols")
value = 0 = 0x0
# Load EPICS Records
# Uncomment Records and change macro substitutions according to your
application
dbLoadRecords("$(TOP)/db/event.db","INST=porter,NN=0,MM=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/runTime.db","INST=porter,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/lksh.db","INST=porter,NN=0,PORT=L8")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/lksh.db","INST=porter,NN=1,PORT=L0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/porterMotor.db")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/posChanger.db","INST=porter,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/motorDev2.db","INST=porter,MDEV=huber,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/motorDev3.db","INST=porter,MDEV=mdev,NN=0")
value = 0 = 0x0
dbLoadRecords("$(TOP)/db/motorDev6.db","INST=porter,MDEV=xyz,NN=0")
value = 0 = 0x0
dbLoadRecords("$(AUTOSAVE)/asApp/Db/save_restoreStatus.db", "P=porter:sr:")
value = 0 = 0x0
dbLoadRecords("$(ASYN)/db/asynRecord.db",
"P=porter,R=asyn,PORT=L8,ADDR=0,OMAX=0,IMAX=0")
value = 0 = 0x0
cd startup
value = 0 = 0x0
oms58Setup(6, 0x3000, 190, 5, 10)
value = 0 = 0x0
iocInit
Starting iocInit
### EPICS IOC CORE built on Mar 30 2006
### EPICS R3.14.8.2 $R3-14-8-2$ $2006/01/06 15:55:13$
reboot_restore: entry for file 'pos.sav'
reboot_restore (v4.7): entry for file 'pos.sav'
reboot_restore: Found filename 'pos.sav' in restoreFileList.
*** restoring from
'/net/iocappsDev/rporter/inst/autosave/porter/pos.sav' at initHookState
5 ***
../dbrestore.c(96):
[0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLEreboot_restore: done with
file 'pos.sav'
reboot_restore: entry for file 'set.sav'
reboot_restore (v4.7): entry for file 'set.sav'
reboot_restore: Found filename 'set.sav' in restoreFileList.
*** restoring from
'/net/iocappsDev/rporter/inst/autosave/porter/set.sav' at initHookState
5 ***
../dbrestore.c(96):
[0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLE../dbrestore.c(96):
file 'set.sav'
Businterface 'L8' not found for 'porter:lksh_0:idnstrg'
porter:lksh_0:idnstrg: Can't attach to bus L8 -1
porter:lksh_0:idnstrg: streamInitRecord failed
Businterface 'L0' not found for 'porter:lksh_1:idnstrg'
porter:lksh_1:idnstrg: Can't attach to bus L0 -1
porter:lksh_1:idnstrg: streamInitRecord failed
Businterface 'L8' not found for 'porter:ls330_0:atype'
porter:ls330_0:atype: Can't attach to bus L8 -1
porter:ls330_0:atype: streamInitRecord failed
Businterface 'L8' not found for 'porter:ls330_0:btype'
porter:ls330_0:btype: Can't attach to bus L8 -1
porter:ls330_0:btype: streamInitRecord failed
Businterface 'L8' not found for 'porter:ls330_0:cuid'
porter:ls330_0:cuid: Can't attach to bus L8 -1
porter:ls330_0:cuid: streamInitRecord failed
Businterface 'L0' not found for 'porter:ls330_1:atype'
porter:ls330_1:atype: Can't attach to bus L0 -1
porter:ls330_1:atype: streamInitRecord failed
Businterface 'L0' not found for 'porter:ls330_1:btype'
porter:ls330_1:btype: Can't attach to bus L0 -1
porter:ls330_1:btype: streamInitRecord failed
Businterface 'L0' not found for 'porter:ls330_1:cuid'
porter:ls330_1:cuid: Can't attach to bus L0 -1
porter:ls330_1:cuid: streamInitRecord failed
Businterface 'L8' not found for 'porter:lksh_0:rst'
porter:lksh_0:rst: Can't attach to bus L8 -1
porter:lksh_0:rst: streamInitRecord failed
Businterface 'L0' not found for 'porter:lksh_1:rst'
porter:lksh_1:rst: Can't attach to bus L0 -1
porter:lksh_1:rst: streamInitRecord failed
*** restoring from
6 ***
reboot_restore: done with file 'set.sav'
iocInit: All initialization complete
value = 0 = 0x0
# Configure autoSave for EPICS autoSaveRestore. (task named "save_restore")
# save positions every five seconds
create_monitor_set("pos.req",5,"INST=porter")
value = 0 = 0x0
# save other things every thirty seconds
create_monitor_set("set.req",30,"INST=porter")
value = 0 = 0x0
Done executing startup script
/net/iocappsDev/rporter/R3.14.8/ioc/Anc/iocBoot/iocporter-172/st.cmd
iocporter-172> ../dbrestore.c(96):
[0x3d0002]=write_it:S_objLib_OBJ_UNAVAILABLE../dbrestore.c(96):
[0x3d0002]=myFileCopy:S_objLib_OBJ_UNAVAILABLEporter:lksh_0:idnstrg:
Record not initialised correctly
porter:lksh_1:idnstrg: Record not initialised correctly
porter:lksh_0:idnstrg: Record not initialised correctly
Dr. Dirk Zimoch
Swiss Light Source
Paul Scherrer Institut
Computing and Controls
phone +41 56 310 5182
fax +41 56 310 4413
- streamDevice/Asyn Error: Businterface not found Porter, Rodney R.
Allen Bradely ControlLogix Version Control ? John Dobbins
RE: Allen Bradely ControlLogix Version Control ? Tang, Johnny Y.
<2006>
2025
2026
RE: streamDevice/Asyn Error: Businterface not found Mark Rivers
<2006>
2025
2026
