1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Undefined symbols R3.14.6
To: [email protected]
Date: Thu, 20 Apr 2006 14:07:29 -1000
Hi Ernest,
Yes. Note we have an image in use for a 3.13.4 release of the app. Just in case, I built a new test image as described. I've even included the line in my makefile (but honestly thought that was for iocsh to work on non-vxworks targets ???).
Anyway, I get the exact same error (save the sntpc line). Am I wrong in thinking you can build and load acctst.c as described?
Thanks again for any help.
-Matt
Ernest L. Williams Jr. wrote:
Hi Matt,
Have you already followed the recommendations at the URL listed below?
http://www.aps.anl.gov/epics/base/T20xConfig.html
Also, in your Makefile I think you need:
test_SRCS+= test_registerRecordDeviceDriver.cpp
Thanks, Ernest
On Thu, 2006-04-20 at 09:26 -1000, Matt Rippa wrote:
Migrating a channel access app to R3.14.6 on vxWorks-mips using tornado2.0. This builds okay but loading the munch file results in:
ld < test.munch
Undefined symbol: sntpcTimeGet (binding 1 type 0)
Undefined symbol: __GLOBAL_$I$.._netiiu.cpp (binding 1 type 0)
Undefined symbol: __GLOBAL_$I$.._.._.._src_libCom_cxxTemplates_epicsSingletonMutex.cpp (binding 1 type 0)
Undefined symbol: __GLOBAL_$I$.._comBuf.cpp (binding 1 type 0)
value = -2131312736 = 0x80f6bfa0
I suspect the vxworks build is missing things and (in fact) I've found an sntpc boot-image that gets rid of the first error. Any hints on the other?
I've stripped my app away completley and am just trying to load the ca regression test from base: $EPICS/base/src/ca/acctst.c
Here's my Makefile:
TOP=../../../../..
include $(TOP)/configure/CONFIG
PROD_IOC_vxWorks += test
DBD += test.dbd
test_DBD += base.dbd
test_SRCS += acctst.c
test_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
test_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
Thanks! --------- Matt Rippa
Re: Undefined symbols R3.14.6 Ernest L. Williams Jr.
RE: Undefined symbols R3.14.6 Thompson, David H.
Undefined symbols R3.14.6 Matt Rippa
Prev: Re: Undefined symbols R3.14.6 Ernest L. Williams Jr.
Next: Re: Undefined symbols R3.14.6 Ernest L. Williams Jr.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
