On Thu, 2006-04-20 at 14:07 -1000, Matt Rippa wrote:
> Hi Ernest,
> Yes. Note we have an image in use for a 3.13.4 release of
> the app. Just in case, I built a new test image as
> described. I've even included the line in my makefile (but
> honestly thought that was for iocsh to work on non-vxworks
> targets ???).
You are right but it also registers record/device/driver support.
> Anyway, I get the exact same error (save the sntpc line). Am
> I wrong in thinking you can build and load acctst.c as
> described?
So, there is probably something else going on?
I did the following since acctst is already built from EPICS BASE:
# Do ca regression test from the IOC as well.
# acctst <channel name> <interest level>
test_OBJS_vxWorks += $(EPICS_BASE_BIN)/acctst
The above worked fine for me.
I would next run the basic getting started "bare-bones" IOC described
in the App Dev Guide and look for those errors again.
Ernest
> Thanks again for any help.
> -Matt
> Ernest L. Williams Jr. wrote:
> > Hi Matt,
> > Have you already followed the recommendations at the URL listed below?
> > http://www.aps.anl.gov/epics/base/T20xConfig.html
> > Also, in your Makefile I think you need:
> > test_SRCS+= test_registerRecordDeviceDriver.cpp
> > Thanks,
> > Ernest
> > On Thu, 2006-04-20 at 09:26 -1000, Matt Rippa wrote:
> >>Hi,
> >>Migrating a channel access app to R3.14.6 on vxWorks-mips
> >>using tornado2.0. This builds okay but loading the munch
> >>file results in:
> >>ld < test.munch
> >>Undefined symbol: sntpcTimeGet (binding 1 type 0)
> >>Undefined symbol: __GLOBAL_$I$.._netiiu.cpp (binding 1 type 0)
> >>Undefined symbol:
> >>__GLOBAL_$I$.._.._.._src_libCom_cxxTemplates_epicsSingletonMutex.cpp
> >>(binding 1 type 0)
> >>Undefined symbol: __GLOBAL_$I$.._comBuf.cpp (binding 1 type 0)
> >>value = -2131312736 = 0x80f6bfa0
> >>I suspect the vxworks build is missing things and (in fact)
> >>I've found an sntpc boot-image that gets rid of the first
> >>error. Any hints on the other?
> >>I've stripped my app away completley and am just trying to
> >>load the ca regression test from base:
> >>$EPICS/base/src/ca/acctst.c
> >>Here's my Makefile:
> >>TOP=../../../../..
> >>include $(TOP)/configure/CONFIG
> >>PROD_IOC_vxWorks += test
> >>DBD += test.dbd
> >>test_DBD += base.dbd
> >>test_SRCS += acctst.c
> >>test_OBJS_vxWorks += $(EPICS_BASE_BIN)/vxComLibrary
> >>test_LIBS += $(EPICS_BASE_IOC_LIBS)
> >>include $(TOP)/configure/RULES
> >>Thanks!
> >>Matt Rippa
- Undefined symbols R3.14.6 Matt Rippa
- Re: Undefined symbols R3.14.6 Ernest L. Williams Jr.
- Re: Undefined symbols R3.14.6 Matt Rippa
RE: Undefined symbols R3.14.6 Thompson, David H.
<2006>
2025
2026
<2006>
2025
2026
