1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: No more CA connections? R3.14.7, 3.14.8.2, CAJ
To: Jeff Hill <[email protected]>
Cc: "'tech talk'" <[email protected]>
Date: Tue, 25 Apr 2006 13:49:44 -0400
On Apr 25, 2006, at 13:33 , Jeff Hill wrote:
Does the thread remain stuck in that subroutine (in asAddClient in the
access security library attempting to register a new client) when you run tt
multiple times?
Well, I have to reboot the affected IOCs rather quickly,
so I can't wait and test for long.
But it just happened on 2 other IOCs, so I now found a total of 3 IOCs
with a task trace like this:
1fa774 vxTaskEntry +68 : 1b60b3c ()
1b60bac epicsThreadPrivateGet+f8 : camsgtask ()
1a777e8 camsgtask +36c: camessage ()
1a7c744 camessage +320: 1a79de4 ()
1a79de4 casUserNameInitiatingCurrentThread+2404: asAddClient ()
1a88cec asAddClient +110: epicsMutexLock ()
1b5787c epicsMutexLock +24 : semTake ()
1f0c74 semTake +13c: semMTake ()
value = 0 = 0x0
I did run tt twice, a few minutes in between, w/o any change.
Pity is that I can't get at the 'static' AS semaphore ID
to run a semShow and see which task is holding the lock.
Our CA security config was changed before this beam test run.
Basically, these a few more hosts were added by name, example:
HAG(phyServers) {ics-srv-phy1,ics-srv-phy2,ics-srv-phy3,ics-srv-phy4}
But those names are not explicitly mapped to IP addresses via "hostAdd".
So could the IOC use NFS to resolve those host names,
and what I see is a result of CA security waiting for NFS?
-Kay
Re: No more CA connections? R3.14.7, 3.14.8.2, CAJ Kay-Uwe Kasemir
RE: No more CA connections? R3.14.7, 3.14.8.2, CAJ Jeff Hill
Prev: StripTool bogs down host? John Dobbins
Next: RE: No more CA connections on different IOC Jeff Hill
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <2006>  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: RE: No more CA connections? R3.14.7, 3.14.8.2, CAJ Jeff Hill
Next: Re: No more CA connections? R3.14.7, 3.14.8.2, CAJ Kay-Uwe Kasemir
