1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: RE: Digitizer needed for LCLS
To: Steve Lewis <[email protected]>, [email protected]
Cc: Elden Ables <[email protected]>
Date: Mon, 01 May 2006 16:09:40 -0400
SNS BLM uses VME ICS110BL module (ICS company).
32 channels and 16/24 bits. The module is expensive :( Company has
another only 16 bits module but company said that it will not be
cheaper.
I also tried to find 16 bits and 32 channels module but there is not big
chance. Maybe you will be more lucky :)
Good luck - Andrei Liyu.
-----Original Message-----
Sent: Monday, May 01, 2006 3:56 PM
To: [email protected]
Cc: Elden Ables
Subject: Digitizer needed for LCLS
EPICS colleagues:
The LLNL group that is supplying the diagnostics to commission the
LCLS needs a digitizer for an energy measurement instrument
(calorimeter) with the following characteristics:
  - 100 channels sampled simultaneously
  - each channel takes 100 samples at 10us per sample (1 ms total time)
  - differential inputs
  - 12 bits minimum; 14 or even 16 bits preferred
  - sampling repeats at 120 Hz major cycle with trigger
A VME or VXI format is ideal.
Any suggestions are most welcome.  Ideally, we can discuss this in
depth at the June meeting.
______________________________________________________________
Stephen A. Lewis                        |
Linac Coherent Light Source             | [email protected]
Lawrence Livermore National Laboratory  | Tel: 925.423.4751
7000 East Ave, L-210                    | FAX: 925.423.1488
Livermore, CA 94550                     | http://www.llnl.gov
Prev: Digitizer needed for LCLS Steve Lewis
Next: RE: Digitizer needed for LCLS Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Digitizer needed for LCLS Peter Milne
