Hi Steve,
Joerger Enterprises makes a VME module which has a mother board and up to 4 daughter cards. One version of the daughter card is 8 channels, 14 bits, 10MHz. So you can do 32 channels on one VME board.
http://www.joergerinc.com/VME.htm
Sent: Mon 5/1/2006 2:55 PM
To: [email protected]
Cc: Elden Ables
Subject: Digitizer needed for LCLS
EPICS colleagues:
The LLNL group that is supplying the diagnostics to commission the
LCLS needs a digitizer for an energy measurement instrument
(calorimeter) with the following characteristics:
- 100 channels sampled simultaneously
- each channel takes 100 samples at 10us per sample (1 ms total time)
- differential inputs
- 12 bits minimum; 14 or even 16 bits preferred
- sampling repeats at 120 Hz major cycle with trigger
A VME or VXI format is ideal.
Any suggestions are most welcome. Ideally, we can discuss this in
depth at the June meeting.
______________________________________________________________
Stephen A. Lewis |
Linac Coherent Light Source | [email protected]
Lawrence Livermore National Laboratory | Tel: 925.423.4751
7000 East Ave, L-210 | FAX: 925.423.1488
Livermore, CA 94550 | http://www.llnl.gov
RE: Digitizer needed for LCLS Liyu, Andrei
Re: Digitizer needed for LCLS Till Straumann
<2006>
2025
2026
Floating point exception running ArchiveEngine Michele Joyce
<2006>
2025
2026
