1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Subject: Re: Digitizer needed for LCLS
To: Steve Lewis <[email protected]>
Cc: [email protected], Elden Ables <[email protected]>
Date: Mon, 01 May 2006 14:08:34 -0700
General Standards Inc. makes a PMC module
with 64 parallel 16-bit digitizers. It can be
configured to 64 single-ended, 32 differential
(digital differences!) channels. Very compact
and not extremely expensive (3.5k); EPICS
drivers available.
HTH
--Till
Steve Lewis wrote:
EPICS colleagues:
The LLNL group that is supplying the diagnostics to commission the LCLS needs a digitizer for an energy measurement instrument (calorimeter) with the following characteristics:
 - 100 channels sampled simultaneously
 - each channel takes 100 samples at 10us per sample (1 ms total time)
 - differential inputs
 - 12 bits minimum; 14 or even 16 bits preferred
 - sampling repeats at 120 Hz major cycle with trigger
A VME or VXI format is ideal.
Any suggestions are most welcome. Ideally, we can discuss this in depth at the June meeting.
Digitizer needed for LCLS Steve Lewis
Prev: RE: Digitizer needed for LCLS Mark Rivers
Next: Re: Who can help with dbLoadRecords()? Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  <20062007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  2025  2026
Prev: Digitizer needed for LCLS Steve Lewis
Next: Re: Digitizer needed for LCLS Peter Milne
