Christophe Moins wrote:
I'd like to use the php epics module but I meet some difficulties.
When I am trying to launch the test_ca_get_put.php example :
<snip>
from a web browser, I have the following display :
*"Warning*: dl(): Unable to load dynamic library
'/usr/local/lib/php/extensions/php_epics.so' - libCom.so: cannot open
shared object file: No such file or directory in
*/var/www/html/ImmsData/test_ca_get_put.php* on line *3"
*although the path to php_epics.so is correct.*
*Does anybody know what's going on ?
Well the error message you're getting says "I can't load the
php_epics.so library because it in turn needs to load libCom.so which I
can't find."
Run 'ldd /usr/local/lib/php/extensions/php_epics.so' to find out where
it's trying to get libCom.so from - it's part of EPICS Base so should be
installed in your base/lib/<host-arch> directory, but if you didn't
compile that php_epics.so file on the web server machine then it might
not be present. In this case you should be able to fix it by copying
libCom.so to the /usr/local/lib/php/extensions directory (you may also
need libca.so in there as well).
- Andrew
There is no S in exprexxo.
- php epics module Christophe Moins
Re: EDM Command Options Question John Dobbins
MIPS epicsEventWaitWithTimeout(() Matt Rippa
<2006>
2025
2026
<2006>
2025
2026
