John,
Apologies. I spoke too soon. It turn out that if I sit at the console I get the
correct focus behavior. This is with Scientific Linux 3 or 4. Exceed also works
for remote access. For me the problem appears to be limited to using CYGWIN for
remote access. Thanks.
John Dobbins
john sinclair wrote:
John,
edm -open should probably popup an existing screen - I'll add this to my list
of things to consider.
If you launch edm as
edm -ctl orib36:screenpv
where screenpv is an epics string pv, then whenever a filename is written to
that pv, edm will attempt to open the file. If it is already open, edm pops
it to the top. Might this work for you?
John Sinclair
On Thursday 04 May 2006 2:55 pm, you wrote:
Dear All,
Note: I am new to both Alarm Handler and EDM.
I am trying to understand the command options for EDM. I would like to make
Alarm Handler open appropriate EDM screens. Alarm Handler provides for
adding a button which will issue a command to the shell. However if I make
that command something like
edm_startup.sh my_screen.edl
Then each time one of the buttons is pushed you get a new instance of EDM
with its own little square top level window.
However if the first instance of EDM is launched with the -server option:
edm -server -display $DISPLAY -x &
Then I can issue subsequent commands in the form:
edm -display $DISPLAY -open my_screen.edl &
which will either
1) open the screen if it is not already open, without starting a new
instance of EDM
2) do nothing if the screen is already open
The problem is that if the screen is already open it is not raised to the
front in which case the Alarm Handler button appears to do nothing instead
of directing your attention to the intended screen.
Is there another way to go about this? Thanks.
John Dobbins
Lab for Elementary Particle Physics
Cornell University
Ithaca, NY
- Re: EDM Command Options Question Devin Bougie
php epics module Christophe Moins
Re: php epics module Andrew Johnson
<2006>
2025
2026
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
