The backward conversion is used in analogue output records. We need this
e.g. for PID loops. A valve opening regulates Helium flow to maintain a
constant temperature. Raw>>eng conversion for the sensor readback for
display to the operator. Eng>>raw conversion used when the operator
types the temperature set-point. The PID is done in a PLC, which just
compares the raw setpoint and readback values.
- rolf -
D. Peter Siddons wrote:
I agree.
I'm not even sure when one would use the backward conversion. Isn't it
always used forwards?
Pete.
Rolf Keitel wrote:
Andrew,
I am not sure if I understand your message correctly. Rejecting
negative slopes (in the second column) of the breakpoint table would
be too limiting. One can always arrange the raw value sequence in
ascending order. The engineering sequence slope is then determined by
your sensor (in our case Si cryo-diodes).
IMHO one doesn't have to go overboard with reengineering, as
breakpoint tables are not really used "on the fly".
Documenting the requirements of monotonous curves in both columns, a
positive slope in the raw column and fixing the code for the backward
conversion would be sufficient for me.
Of course, dynamically reloading of breakpoint tables at run-time
would be nice.
- rolf -
I had also just run into this. It is also a bug in the makeBpt
program to generate a table from raw data. It produces nonsense if
the raw ADC values are in decreasing order and the engineering
values are increasing. I didn't try it with positive slope but
reversed data order. I thought that simply reversing the table
order fixed it, but apparently not.
Rolf Keitel wrote:
There is a problem with break-point table conversion from
engineering to raw values ( function cvtEngToRawBpt in file
cvtBpt.c).
The function returns incorrect results, if the breakpoint table
has negative slopes, i.e. if engineering values decrease with
increasing raw values.
I couldn't find anything in the documentation when I looked briefly
the other day, but I don't think the present breakpoint table code
was ever supposed to work with negative slopes. Given the
limitations of the existing code though it really ought to check its
inputs properly and refuse to load a breakpoint table that slopes
downwards.
Any replacement code that permits negative slopes should reject
curves that are not continuously increasing or decreasing but have
local minima or maxima - I have no idea what the existing code does
with such curves, but I doubt that it's pretty. We would also like
to be able to reload breakpoint tables at runtime (which I believe
Benjamin Fransken implemented for BESSY but this isn't available in
the official release).
Any offers to do a proper re-engineering of this (fairly
self-contained) area of functionality in EPICS Base? If no-one
offers I'll try to put in the positive slope test, but if a site
needs more than that it'll have to donate some effort towards
implementing it.
- Andrew
| Rolf Keitel, TRIUMF Tel: (604) 222-7453 |
| Group Leader ISAC Controls Fax: (604) 222-7307 |
| and Electronics Development |
| Vancouver, B.C., Canada |
- bug in break-point table conversion Rolf Keitel
- Re: bug in break-point table conversion D. Peter Siddons
- Re: bug in break-point table conversion Andrew Johnson
- Re: bug in break-point table conversion Rolf Keitel
Document, visualize SNL code? Kay-Uwe Kasemir
<2006>
2025
2026
<2006>
2025
2026
ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
