The ai record uses cvtRawToEngBpt(), but the ao record actually calls both cvtRawToEngBpt() and cvtEngToRawBpt(), since some device support layers can read the current output value from hardware registers at reboot time and convert this back to the correct engineering units value, thus supporting bumpless reboot for those channels. Note that it is possible (if unusual) to use the same breakpoint table for both input and output conversions. I also wrote privately to Rolf yesterday; I'll incorporate our conversation back into the public list in this reply: Rolf Keitel wrote: Andrew Johnson wrote: Since the algorithms are identical with just eng and raw swapped, I claim that we do need to make equivalent changes to the cvtRawToEngBpt() routine - the two are mirror images of each other, the only difference being whether you divide or multiply by the slope. I agree that we should be able to support curves with negative slopes, but I was trying to avoid spending much time on adding that support myself. However while writing this reply I added the necessary tests to the parser routines to check that the engineering units values always increase and that the breaktable slopes always have the same sign. I'm not convinced that's right; the sign of the slope depends on both the sign of the difference between adjacent both engineering and raw values. The calculation does this: slope[i] = (eng[i+1] - eng[i]) / (raw[i+1] - raw[i]); It makes no difference to the slope value if you swap the order of the samples in the interval, as you'll just change the sign of both the numerator and denominator. That same calculation is used whether you're going to be calling cvtRawToEngBpt() or cvtEngToRawBpt(), and in fact the parser doesn't know which of the two you're going to use the table with. I think one should leave everything else up to the breakpoint table designer. There may even be some value of allowing both slope signs in the engineering sequence, as long as the slope in the raw series is always positive. This would allow for analogue input records to handle such things (although the same conversion in an output record would fail due to ambiguity). There is only one slope calculated as above for each interval, which is used for both raw -> eng and eng -> raw calculations, so your sentence "as long as the slope in the raw series is always positive" doesn't make sense. Ok, I duplicated your example in the other routine, and did some other restructuring to reduce the memory allocation requirements of each table. I haven't completed testing the result yet, but I'm working on it. - Andrew -- There is no S in exprexxo.
| ANJ, 02 Sep 2010 |
Home
News
About
Talk
Base
Modules
Extensions
